Old 05-18-2010, 11:32 AM   #21 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Heh, that's probably your secret to the mad mileage$, yo. I bet you've got a biomass gasifier in there, so the more bugs and grass clippings you collect, the less gasoline you consume.
Old 05-20-2010, 05:33 PM   #22 (permalink)
Originally Posted by Wonderboy View Post
the SGII can't account for distance traveled while the engine is off. This is one of those things I can just feel though - I can tell its working pretty well.
I don't know if you are using the key or a kill switch to shutdown the engine but I wonder if you just go to set-up and change your SGII vehicle to a hybrid if it will keep on working for you. Might also have to change the cut-off setting.
Just a thought.
Old 05-21-2010, 12:04 AM   #23 (permalink)
Wonderboy's Avatar
Heh, This thread has officially become a zombie thread. I posted that ages ago before I even knew there was a hybrid setting. Now I'm not even using the SGII. Thanks for the input though.
Old 02-27-2013, 10:54 AM   #24 (permalink)
LibbyMetro's Avatar
Da' Honda - '98 Honda Civic EX
90 day: 36.79 mpg (US)
Thanks to you and PaleMelanesian for making these threads, I have a 1998 honda civic that I am taking on a yearly trip to vegas for the races next week, and I stole your idea of this grill block, made mine from plexiglass as well 1/8'', which is horribly expensive here, and cut it with a dremel tool, will attach it today.
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 6 12-21-2014 09:58 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
2005 Civic Upper Grill Block Harpo Aerodynamics 13 03-17-2008 11:55 AM
