Old 10-06-2008, 07:51 AM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I did a similar thing like TomO on my Tercel. You can check it out here.
Old 10-06-2008, 09:40 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
those pvc jobbies are pretty cool
with the right application of heat you can bend the pvc as well:
Bending PVC pipe. How to Bend PVC Pipe
Old 10-06-2008, 12:09 PM   #13 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Originally Posted by Dust View Post
I:m looking for way to get it mounted. PVC to plastic, plastic in DIN. I guess I should look for a 2.5 by 2.5 spot to put the gauge, or just buy a pod for $10. What kind of glue did you use for the PVC to ABS mount?
I used PVC cleaner on the ABS and The PVC, let it dry overnight and then glued the PVC to the ABS via Gorilla Super Glue. I attached the ABS/PVC assembly to the DIN opening via 3M double sided foam tape, some of the stringest, cleanest removing double tap there is.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 10-06-2008, 12:13 PM   #14 (permalink)
That VX guy!
TomO's Avatar
That was very similar to what I wanted to do with my gauges in the first place. But owning a civic hatch in MN is a dangerous thing when you live in certain places, especially if you have gauges in plain view for thieves to see.
Old 10-09-2008, 08:55 PM   #15 (permalink)
'El Misil' - '91 Calibra 2.0i
Last 3: 29.02 mpg (US)
That's a very cool DIY idea .
Old 01-26-2009, 09:54 AM   #16 (permalink)
Unhappy tachs
hi i have a 96 metro and in have a turbo with 4 pounds of boost with a vac meter, but i just cant figure out how to hook up the tach if you cuase email me pics or send me directions that would be well appreciated, thks, i will send pics
Old 02-04-2009, 04:04 PM   #17 (permalink)
Tracy - '00 corsa
Originally Posted by lyd View Post
3 1/2" tach. (yes, it is too big, but I didn't want to bother with modding the 2" for 3 cyl.)
why do you have to mod a rev counter to work for different number of cylinders? surely all revs are created equally?
i have a 3 cylinder too
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 02-04-2009, 04:09 PM   #18 (permalink)
CM400E - '81 CM400E
Tachometers measure when each spark plug fires, you have to divide this by number of cylinders to get the correct rpm.
Old 02-10-2009, 02:12 PM   #19 (permalink)
Civic - '98 Civic DX
90 day: 41.44 mpg (US)
these look pretty cool.
