Old 03-27-2008, 10:23 PM   #1 (permalink)
Vacuum forming--may be useful for boat tails, etc..
What do you think?
Old 03-27-2008, 11:26 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Very cool. I wonder what kind of plastic he used... too lazy... to .. go .. check.. web.. site...
Old 03-27-2008, 11:30 PM   #3 (permalink)
pontiac trans am - '00 firebird trans am
jeep 1 - '02 wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Corolla lx
i think thats great, it would work wonderfully for aero light lenses/covers if you used clear plastic. thanks for the video, verry informative, only question i had was what temp do you set the oven to?
Old 03-28-2008, 02:53 AM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
A friend who teaches industrial design at the local university is attempting to find a misplaced book for me on making parts for stage sets made with a "$100 vacuum former" using peg board, a shop vac, and some heat lamps I suspect, ABS plastic, and Lexan are two that I have been told will work, lexan is clear and is often used in place of glass for windows, if you get it thick enough (half inch I think) then it's practically bullet proof!
Old 03-28-2008, 03:00 AM   #5 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
PETG (soda bottle plastic) also works It's cheaper than lexan and has a lower sag temp
I've heard delrin can also be vacuum formed - but IIRC it's basically nylon and I don't think it's clear... But, it's much better at resistance to cracking like lexan (PETG being a little better than lexan).
We had to do this research last year for the HPV build (just passing that info along )
Challenge me, or correct me, but don't ask me to die quietly.
Old 03-28-2008, 03:01 PM   #6 (permalink)
go vacuum forming!
Many years ago,I got a tour of a local manufacturer of marine plastic parts.Electric "pizza" ovens were used to heat ABS sheeting until it drooped,then the material was quick-clamped over a wooden form,to a vacuum table,which was connected to an accumulator,in turn connected to a large vacuum pump.A foot-operated valve enabled vacuum to be transferred,parts were made in less than a minute,then sent to a trim -fixture,where a router cut away "flash",rendering the finished part.I've seen ABS ponds at HOME DEPOT larger than the front of a car,which can be purchased for $150.00,U.S..My thought was,that a complete streamlined automotive front end could easily be produced for $150.00.I still do! Conversely,a boattail could certainly be produced in the same way.And anything else for that matter.And that's "RETAIL" pricing,complete with middlemen,and profits!
Old 03-28-2008, 03:37 PM   #7 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Google's use of keywords creates some interesting ads that really class the place up...
I doubt a true boat tail could be made with enough structural integrity, unless specific supports were molded in place. It would be useful for small scale parts though (i.e. tire boattails).
- LostCause
Old 03-28-2008, 06:33 PM   #8 (permalink)
Cd
Ultimate Fail
Cd's Avatar
- LostCause
Someone at Google has seen one of our penis shaped cars apparently.
Anyone know the .Cd of a penis in a windtunnel ?
O.K. ............ back on topic !!!
What is the largest size that can be formed on one the home kits ?
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 03-28-2008, 11:08 PM   #9 (permalink)
i would think it would be limited to the amount of area that you can heat and also the strength of the pump... just a thought, there might be more that goes into it but that seems like the biggest limiting factors
Old 03-29-2008, 12:10 AM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I've seen this used with model planes, but nothing larger than around 12".
The only thing that would worry me would be the fumes .
Interesting process though. Looks easy too !
Woo Vacuum Pump! trebuchet03 The Lounge 10 05-14-2010 01:52 PM
