Old 01-21-2011, 01:31 AM   #1 (permalink)
the green machine :P - '97 Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Talking vacuumizing fuel for better economy
has anyone else added a quart jar of gas to the vacuum lines of the car???? i did and got about 7 mpg increase on my 1997 jeep grand cherokee the only bad thing is that it only really gives my the gains in economy if i hold a sufficiant amount of vacuum. I have a 8 gallon compressor i modifide to fit under my jeep that i'm going to fell with 5 gallons of gas and i want to add a 35 inch pound vacuum pump to it and have a ball valve to control the amount of fuel the pump sucks out by connecting the ball valve to the throttle so i have gains throughout the throttle position.
Old 01-21-2011, 02:31 AM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Old 01-21-2011, 08:30 AM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I think what Frank is trying to say is: sounds a lot like nonsense.
Old 01-21-2011, 10:52 AM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
How does it compare to dumping the quart jar of gasoline in to your fuel tank?
Basically what you are doing is vaporizing the fuel, leaving behind the thicker varnish.
The good way to truly test this would be to put a valve on your vacuum line so that while you are driving you can disconnect it, otherwise you are just adding fuel vapor to your intake and at that point the question is, what are you going to do with a tank or jar of varnish? most modern cars already run with the fuel tank under a slight vacuum to prevent vapor emissions, you are just taking it to the extreme and causing the fuel to boil in your jar.
Old 01-21-2011, 11:20 AM   #5 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
I'd like to know how on earth 7mpg gain was calculated.....
Old 01-21-2011, 02:34 PM   #6 (permalink)
21mpg to 28mpg/24 gallon tank to 680 miles!!! i'm 3/8's the way through a tank and i have 320 miles
i know it sounds ridiculous but i'm getting that fuel economy and i'm not doing anything else but acetone it does drop the FE quit a bit driving on the highway though cause i have to stay at a TP that has to low a vacuum to work efficiently
Old 01-21-2011, 02:57 PM   #7 (permalink)
How to properly test modifications (AKA: don't believe every MPG claim you read)
Old 01-21-2011, 03:33 PM   #8 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...LOVE Stan Laurel & Oliver Hardy!
...HATE snake-oil MPG contraptions!
Old 01-21-2011, 07:11 PM   #9 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
I dunno...
On the one hand, it might possibly (and I am going out on a limb here) be a rather novel form of heterogeneous charged combustion. That is, a pocket of stoich air/fuel mix is developed within a homogeneous mixture of much leaner air/fuel mixture, and the result is burned within the combustion chamber. The stoich pocket reliably ignites, and reliably burns the rest of the mixture inside the chamber. Modern cars with direct injection can do this easily.
On the other hand... Well, there is the question of the procedure used to test this claim. I am pretty skeptical right now.
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
Old 01-22-2011, 01:30 AM   #10 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
Judging by the fuel gauge is a sure way to see whacked out data. Extrapolating from gauge position is an excellent way to exacerbate that whacked data.
Case in point
In my civic I have a 11.9 gallon tank. I can go 150 miles at 50mpg before it drops off of the full peg (that's 3 gallons used gauged by an MPGuino). If I use an extra gallon to go to 200 miles it drops to just above the 3/4 mark. If I look at the fuel gauge at that point it looks like I have used only a quarter tank on the gauge which is just shy of 3 gallons. 200 miles by 3 gallons is 66MPG that is about a 15 mpg error if I go by the gauge.
Moral of the story is get an average of a couple tanks with the mod and without as a bare minimum for getting an estimate of the effectiveness of your mod. It would be better if you could eliminate the variables of changing driving conditions but we know that it is not always possible when testing a mod for your self. Gauges are indicators, right now you have an indication of a great boost in mileage we are looking forward to some real data. Don't forget to include the fuel you are sucking in the vacuum lines in your total fuel for the tank.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
