Old 03-30-2009, 01:00 AM   #11 (permalink)
Just wondering where you where getting your VSS signal from. The only reason I ask is I am about to install one in a 95 F-150 and when I was going over the wiring I noticed two separate places to get it. Raw from the sensor or VSS after it connects to the dash. (i.e. I have two wire from the sensor into the dash then VSS signal out to cruise control.) (Was wondering if the PSOM cleans up the signal at all.)
So just wondering where did you tap your VSS from, the sensor / cruise control / PSOM, Also your injector feed, did you get it from the injector rail or right at the computer?
Old 03-30-2009, 02:13 AM   #12 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
I would say the cruise control wire is the best place to get the signal. The one coming off the vss might be an AC signal or noisy and the PSOM module probably cleans it up.
As far as injectors whatever is easiest to get to is best
My Convertible Metro XFI Plug in Hybrid Project build log
Old 03-30-2009, 07:42 AM   #13 (permalink)
zed sled - '74 260Z turbo/MSefi
Franklin - '98 Forester
Send a message via AIM to myplasticegg
I got everyting from the engine computer plug on my ranger. The 12V wasn't good enough and I ended up having to re-flash my board. I now run power from the fused cig lighter spot on the fuse box.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
How to Debounce a Geo Metro VSS Coyote X OpenGauge / MPGuino FE computer 19 07-26-2011 10:22 PM
VSS Input Voltage Requirements davchar OpenGauge / MPGuino FE computer 6 09-21-2008 08:39 AM
VSS Signal assistance? dcb OpenGauge / MPGuino FE computer 32 09-20-2008 11:58 AM
[CRXMPG Mailbag] SuperMID and VSS Issues with EF Civics SVOboy Instrumentation 0 02-03-2008 04:33 AM
