Old 07-07-2008, 02:36 AM   #1 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
veggie oil weight does matter
today i took the Chevy Colorado to go get a hundred plus gallons of vegetable oil.. the best i was able to pull off was 33.5 MPG usually i can break 35 mpg for a round trip.. weight surly matters .. I had the two 55 gallon barrels tucked up next to the cab witch should have helped areo-dynamically.. the barrels weigh about 300 pounds each i was hauling about 600 lbs of raw oil and my MPG surly was hit by the added weight.
Old 07-07-2008, 07:45 PM   #2 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
What are you hauling Veggie oil for?
In town, I'll bet it (weight) matters a good bit
On the highway I'd say that the tires would be the primary determining factor . . .
So you are estimating 6 lbs/ gallon? I was thinking it was more like 7~8 lbs/ gallon. Maybe I can haul 100+ gallons with the golf after all.
6 speed ALH TDI
Old 07-08-2008, 03:36 PM   #3 (permalink)
Water weighs 8.33 pounds per gallon, and most of the things I've read use that same 8 pounds per gallon weight.
I think the OP had 600# of oil in two 55 gallon containers, but they weren't full of 55 gallons each (that would have been 440 pounds each, or 880 total).
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
VW pickup for conversion to electric or veggie oil? bennelson Fossil Fuel Free 16 02-12-2009 07:13 AM
My odd ball veggie oil hypermiling ebacherville Hypermiling / EcoDriver's Ed 5 05-16-2008 02:28 AM
Good Veggie Oil conversion!?!? bennelson EcoModding Central 12 02-14-2008 11:09 PM
Oil weight question: 0w30 or 5w20? MetroMPG EcoModding Central 4 11-25-2007 09:57 PM
