Old 12-11-2011, 10:47 PM   #41 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Does electric drive have the same regulations as gasoline where you are?
Old 12-12-2011, 03:28 PM   #42 (permalink)
efficiencyguy
I have no detailed knowledge of these regulations.
I think the regulations for electric drive are less strickt.
I have a electric motorbike based on the same Honda Innova as Allerts honda.
I had to get the licence changed from gasoline to electric drive.
I did not alter the frame, wheelbase, brakes etc.
It was very easy, I paid about 175 euro for a test.
A guy came to visit my bike at home, walked around it 4 times.
nodded a lot and checked the frame number. done.
No details are documented so i can easily change motor, batteries etc.
You can see it on FNS
It's all in dutch but with pictures.
greetings, Theo
Think twice, be nice..
The Following User Says Thank You to theo22 For This Useful Post:
NeilBlanchard (12-12-2011)
Old 01-14-2012, 02:20 PM   #43 (permalink)
sendler's Avatar
Honda CBR250R FI Single - '011 CBR250R
90 day: 92.93 mpg (US)
Ninja 250R SE Green - '09 Ninja 250R SE
90 day: 65.9 mpg (US)
2001 Honda Insight stick - '01 Insight manual
90 day: 60.68 mpg (US)
2009 Honda Fit auto - '09 Fit Auto
90 day: 32.56 mpg (US)
Kawi Ninja650 - '07 Ninja650
90 day: 65.5 mpg (US)
Adding some fairing below the center of the body can help with side winds by getting the center of pressure lower in relation to the center of gravity on the roll axis. Even though you are increasing the total side area. The ultra low center of gravity of a scooter drive train works against cross wind performance by anchoring the bottom of the bike and shifting all of the side movement to the top where it tries to blow you over into a lean which is the wrong way. My CBR250R is exceptional in cross winds as the bottom of the bike seems to get blown to the side more than the top so the it magically steers itself into the wind which I am assuming is due to the relationship of the center of pressure being below the CG of the roll axis. I would also try covering the rear wheel right down to the ground clearance level which will be more aero and may even help in cross winds. I may try a DIY disc cover for the rear wheel of my bike. Increasing the storage hatch to include a helmet fairing would give more storage and improve the fuel usage numbers. But all in all, this is a beautiful machine and makes me wonder why Honda doesn't build anything like it themselves.
Old 01-16-2012, 09:42 PM   #44 (permalink)
sendler's Avatar
Improving stability in side winds may also be possible by chopping out the head angle a few degrees to increase trail. Thanks to Ken for this great explanation of the phenomenon of a motorcycle's ability to self correct into a side wind.
http://ecomodder.com/forum/279936-post99.html
Old 03-21-2012, 12:13 PM   #45 (permalink)
That is amazing
Sorry, new users are not permitted to post links in their signatures.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Video: Honda scores with 98 mpg (US) CBR125R motorcycle MetroMPG Motorcycles / Scooters 29 07-20-2011 05:01 PM
214 mpg with DIY aerodynamic fairings on Honda 125cc motorbike SVOboy EcoModder Blog Discussion 6 01-30-2010 09:29 PM
