Old 10-21-2014, 05:47 PM   #321 (permalink)
Hyosung - '07 Hyosung gt250r
90 day: 55.49 mpg (US)
Burgman - '07 Burgman 650 k7
Originally Posted by sendler View Post
Eliminating the opening for the air pressure difference to vent across your legs can make the bike more susceptible to being blown off course by side winds.
I know that the current set-up acts like a sail since only 1 side is covered, so there will be a noticeable improvement. Once I add it I will do my best to fully seal it, and might add a large hollow tube to balance pressures.
Old 10-23-2014, 10:17 PM   #322 (permalink)
Check out sailplane plans for body shapes such as www.vintagesailplaner.com/Sheet1bis-9.pdf
The Following User Says Thank You to Grant-53 For This Useful Post:
renault_megane_dci (10-24-2014)
Old 10-25-2014, 02:42 PM   #323 (permalink)
Ninjette - '05 kawasaki EX250
I have been eye-balling the Bocian plans for a while. Nice shape. Pretty sailplane.
The Following User Says Thank You to JeffM For This Useful Post:
Grant-53 (10-25-2014)
Old 10-25-2014, 06:24 PM   #324 (permalink)
I grew up around gliders in Dansville, NY. The landing pattern came over our house. Now I live near the National Soaring Museum. There are many designs available but what I liked about this one is the similarity to the Morelli/Aptera optimal shape and that the curves are simple arcs and ellipses. The shape should be very stable in cross winds with a low nose to reduce lift and a high tail to clear the exhaust. If you want, let the curve come to the shoulder and add front and rear helmet fairings.
Old 05-25-2015, 09:24 AM   #325 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
The Vetter team is still hard at work experimenting with getting the best drag coefficient on a motorcycle. Alan's new lowboy frame mod and seat back bulkhead should be a big improvement. Chapter 87 in a 10 year ongoing campaign.
2015-Fine tuning the streamliners for the 2015 Challenges chapter 87
