Old 04-24-2009, 01:07 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
VFD Display
FYI, I did get to play with a VFD. Documented in the code hacks wiki page, it was pretty trivial to add after getting LCDs working.
Old 04-24-2009, 10:20 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
Followup: I did road test it, and I've already switched back to the LCD The display was very responsive and probably would be less prone to extreme low temps BUT
1. It drew a LOT of current. I couldn't keep my finger on the regulator, even on lowest brightness setting. It eventually went into thermal shutdown. The input diode wasn't real happy either.
2. If it gets into direct sunlight, it becomes completely unreadable even at highest setting. I tried to bounce it off the windshield, but couldn't see anything.
3. it is like 3.5 times the cost of an LCD.
So I cannot recommend the VFD approach at this time, ah well. Will update wiki.
Old 04-24-2009, 10:36 AM   #3 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
That's too bad, VFD's look so cool.
It looks like 16x2 VFD's can use up near 150mA, as opposed to the regular LCD's, which use about 4mA...so yea, power definitely becomes an issue. Even with all the pixels off, the VFD I was looking at uses about 10mA, which is 2.5x that of an LCD that's on.
Old 05-25-2009, 01:27 PM   #4 (permalink)
hu_man's Avatar
If you add a smoke colored plastic lense in front of the LCD it should help with the glare and sun light I think moving it back from the lense will also help. I have a digital dash in my chrysler and it uses the same display. The instrument cluster has a dark tint to it and it is shrouded some by the dash board. This may help. As for the Voltage regulator I do not know as I have no schematic but maybe a seperate one for the display. I would like to use a larger display as my eyes are not as good as they use to be any ideas??
Hugh
No display on MPGuino LCD, just backlight Wingmn OpenGauge / MPGuino FE computer 27 02-06-2009 06:27 PM
ScanGauge Rear Window Display? cfg83 Instrumentation 4 09-26-2008 12:31 PM
Can you change the scanguage display "rate" default to FAST? blackjackel Instrumentation 8 08-27-2008 02:09 PM
Analogue MPG display using an OLED? ecoxantia Instrumentation 2 08-22-2008 08:23 AM
2x16 LCD Display issues/discussion dcb OpenGauge / MPGuino FE computer 29 08-19-2008 07:25 PM
