08-22-2008, 10:25 PM
#21 (permalink)
Why do they always have to plaster a fake grill on the front of the car even when it doesn't need a front opening for cooling? If it doesn't need that front opening, they should have a smooth rounded surface on the front, not those recessed grill blocks. Although they got the generalized aero right, it looks like they compromised on a few of the details to follow "automotive tradition". I guess the Volt's styling isn't quite as revolutionary and aerodynamically functional as they claim it is.
Tacking fake grills on a car is almost as bad as tacking fake shutters onto a house, another one of my pet peeves.
08-23-2008, 12:36 PM
#22 (permalink)
Hi Basjoos,
Yea, I agree. The Prius got away from that front grill, with the little smile gril.
They still have the wheel house bulges on the Volt, too. Not good. This is the socalled "muscular look". Originally, those were mimics of add on fender flares. The flares were a aftermarket thing to allow safe use of bigger tires (and avoid throwing stones into other cars, or have the fender cut the tire). Over time, it became design lanquage for a car with extra HP. So, its just "leaned behavior" hogwash that they would put those into a new design, rather than something that truely improves performance.
One good thing on the wheel houses, is they have a very small gap to the tires. You cannot see that on this video so much, but go over to Charlie Rose web sight, and search on Lutz. BTW, Lutz said the production volt has a Cd of .28.
I think I will be adding the 5 mm Gurnee flap on my Prius though. I have some "FOAMIES" 6 mm thick sheet stock which I wll do this with.
08-23-2008, 03:19 PM
#23 (permalink)
counts
Originally Posted by Tango Charlie
What are 'counts of aero' ? Is this a GM buzz word, or is it an aerodynamics's term?
Doax is correct.I have only two sources which use the term.One a 1982 article by Road & Track,the other Mechanical Engineering Magazine.
---------------------------- The term is considered valid when associated with a particular development vehicle ( like the Volt ),in a particular wind tunnel ( like GM's).
------------------------------- Also,Road and Track "rounds" counts within Cds published by carmakers.
-------------------------- Example: A Firebird,which scored Cd 0.316 would be rounded up to 0.32. A GMC S-15,with Cd 0.495 would remain 0.495,and a car with Cd 0.294 would receive 0.29.
-------------------------------- So like the discussion about the CRX HF,and CRX Si,they may have only been separated by a few "points",however when "rounded",look more dramatic in efficiency differences.
------------------------------ I suspect other magazines also "round." Very frustrating when attempting to distinguish individual features,adding or detracting from aero efficiency.
--------------------------------------- To cloud matters even further,the EPA does not recognize"protuberances" when factoring sectional area.If a vehicle is tested with antenna and sideview mirrors,their area is not factored into drag measured,leading to an arbitrarily high Cd.
-------------------------- Drat!!!!!!!!!!! A can of worms!
08-23-2008, 11:53 PM
#24 (permalink)
Recycling Nazi
”Why do they always have to plaster a fake grill on the front of the car even when it doesn't need a front opening for cooling? Although they got the generalized aero right, it looks like they compromised on a few of the details to follow "automotive tradition".
Guys, GM is trying to sell the notion that enviro-friendly, high-tech vehicles can be practical, cool and even a little sexy. That’s why they styled the volt to look muscular ... as if it was the forthcoming Camaro’s lil’ brother.
I’d prefer a straight-up form-follows-function design … but I’m weird. I know why GM is doing what they’re doing … they’re trying to sell green tech to the unwashed masses that won't buy something that looks like an egg ... or your Honda. So, I cut GM a lot of slack in this area.
--- Bror Jace
08-24-2008, 12:03 AM
#25 (permalink)
Hi Bror,,
In other words, Homer Simson's brother works in the design deparment of GM, and they invited Homer (otherwise known as marketing group studies) into design the car. Maybe you have seen that Simpson's episode? It did not turn out good for anybody.
08-24-2008, 11:36 AM
#26 (permalink)
Recycling Nazi
Yep Donee, until a few years ago, I've seen every episode of The Simpsons.
But I don't think it's a good analogy ... at least a far-less-than-perfect one. Homer, a perfect idiot, ended up with an over-sized monstrosity packed full of every feature one could dream up.
The volt is a fairly attractive car ... if you like the modern muscle car look.
--- Bror Jace
08-27-2008, 04:40 PM
#27 (permalink)
I think Chrysler is still stinging from the 1934 Airflow.The Volt won't help us if it doesn't sell,and so the "moderate" within me will allow for some styling concessions.Commuting 40 miles a day on solar electricity is worth a concession or two.Perhaps down the road,consumers will be more comfortable with eggs.If Volt owners start asking GM dealers about basjoos aero "styling",in a positive light,it may open the flood gates to real wind tunnel winners in the nearer future.Hope so.
08-27-2008, 07:04 PM
#28 (permalink)
After what GM did with the Impact, I worry about the Volt. The team at Aerovironment had to butt heads with the GM design guys to save that design from mediocrity, and then GM management eventually trashed it anyway.
Many years ago, GM and Firestone were fined for conspiracy to eliminate the competition of municipal transit systems. They had bought them up, and not shut them down in any obvious way, they just transferred their incompetent executives there to eventually fire themselves.
08-27-2008, 08:51 PM
#29 (permalink)
Originally Posted by lunarhighway
maybe they mean Cd?
there's an interesting bit about the rear spoiler, where the first version is straight and the second seems to have something which reminds me of a gurney flap.
i've seen certain BMW's wich also have a small gurney flap like spoiler added. and quite a number of cars with a slight upward sweep to the rear spoiler lip.
given it's shown in this video i wonder what it's use is and how it works to aid FE. it would be a relative simple and good looking addition to my car, but i'd like to understand better what it's supposed to do.
A big feature like a trunk-mounted spoiler may build up pressure ahead of itself to prevent separation on a back window. However, the small lips that sharpen trailing edges are intended to gather the existing boundary layer and trip it into the trailing vortex in an organized fashion, so that there are fewer sub-eddies. It is better to have one or two large, stable circulation patterns in a "trapped vortex" than just chaotic flow.
08-28-2008, 06:06 AM
#30 (permalink)
so adding a small ridge just ahead of the trailing edge could be beneficial for FE...
what i don't get is why GM seems to be strugling wich the mucle car look and it's aerodynamics.
in europe trough opel GM has produced some examplary aerodynamic vehicles with cd's between 0.29 and 0.26, from the 80's untill now and with the upcomming opel insignia with a Cd of 0.27 they show they still got it.
and lets not forget the eco speedster... not suitable for the road but certainly a door aero exercice and that car's nose did look like the volt a bit.
there's people working at GM that can totally put together a working practical car with good even sporty looks and top of the line aerodynamics.
just let them do their job and put in an electric engine and slap on whatever badge they want... now remind me again but didn't GM already had some sort of electric engine somewhere they could put in....
08-28-2008, 07:49 PM
#31 (permalink)
small ridge
I think the "small ridge" was a concession to the stylist.With the wind tunnel they can fine tune with clay,and with smoke wand or rake,and capacity to do real-time lift/drag measurement,they know exactly what's going on and if it's a winner.What a fabulous tool,that wind tunnel!!!!!!!!!----------------- Without such a "toolbag" it's a little tougher for us to do that kind of fine-tuning.--------------------- The upshot for you is that you will not have to please a committee or marketing director,and can be more "daring" and "adventuresome" with your mods.----------------------- I think Bicycle Bob has a very good handle on what GM is doing with the Volt,with respect to the "small ridge" and how it effects the wake.Perhaps with tufting or lamp-black and oil,etc. you could pull off a great functioning wing/spoiler with even higher "voltage".
08-29-2008, 01:56 AM
#32 (permalink)
08-29-2008, 05:38 AM
#33 (permalink)
i must say that looks much better than the prototype. those topshots are nice to, often they tell more about a cars aero than the side profile.
the rear wheel arches make more sence as they're probably the result of some heavy boat tailing early on, which leaves the wheels outside the main body... stylists will like this as with some visual tricks they can make it appear as if the car has a wider track in the rear than the front.
the fornt half of the car reminds me a bit of the citroen C4 coupé
wich has a Cd of 0.29... not to bad for a rather tall hatchback
i suppose the stylists where not to happy to see the squared muscle car face go.
08-29-2008, 07:28 AM
#34 (permalink)
Hi All,
Anybody notice the V's in the wheel design? Kinda like the arrow in FedEx logo.
09-23-2008, 03:14 PM
#35 (permalink)
Captain Slow
Added to post #1 up top: a pic of the rear quarter corner and quote from the designer about the function of what he calls a "vertical fin" element.
09-23-2008, 07:03 PM
#36 (permalink)
Pokémoderator
donee -
Originally Posted by donee
Hi All,
I can't see the V's, but I can see something I do like :
Asymmetrical Wheels :
I doubt it will make it into the final version, but it's nice to see.
I also like the fins. Finally a form-follows-function excuse to incorporate fins (or at least finlets).
CarloSW2
09-23-2008, 09:07 PM
#37 (permalink)
I was just reading in Autoweek magazine that the Volt has an "active" grill with slots that open based on cooling needs. Otherwise, the grill is closed for aerodynamics. Cool.
09-25-2008, 02:24 PM
#38 (permalink)
Rolls Royce did that on their earliest cars, and still retain the "Jalousie shutter" styling in their famous grille. Thermostats and water pumps that are designed to be blocked are slightly less efficient than a pump designed for full-flow, too.
09-26-2008, 04:48 AM
#39 (permalink)
new bmw's have this feature too, quite a bit behind the grill there's a series of shutters that interlock when closed. I saw this once on a parked bmw 1 series and while i can't find much detailed information on the web but interestingly i came across i site which lists engine management error codes which has a couple of errors related to "grill shutter" malfunctions.
