Old 09-28-2011, 03:09 AM   #1 (permalink)
The Move - '99 Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust Send a message via Skype™ to Dust
Voltage to frequency converter
I have a 0-5V signal that I would like to convert to a negative pulse. Wanting to mimic a fuel injector, but it doesn't need much power behind it. The signal will control an injector. I have searched online but I can't make sense of the diagrams, so I am just looking to buy one already made. Where should I be looking? What should I be looking at paying?
Old 09-28-2011, 08:39 AM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
sounds like you need a 555 timer, search for that and you should turn up something.
Old 09-28-2011, 10:28 AM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
I agree with the above. The 555 is a very basic chip that does tons more than it is given credit for.
I think Vellman sells a few 555 PWM kits. You may need to swap the inputs to make them go negative.
I can make you a diagram if you know what durations you will need.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-21-2011, 05:07 PM   #4 (permalink)
Jason, I need it to echo or simulate fuel injectors.
Old 11-23-2011, 03:48 PM   #5 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
That is like saying you need a car with wheels.
What frequency pulse ?
What duration ?
What ratio of high to low ?
If 555 schematics are too much, I really reccommend getting a Velman. Easy to solder, some are prebuilt....... K8004: VELLEMAN INC.: Education & Hobby they list it as a Expert kit........
If you can use a knob this QKits Electronic Kits: MX033, PWM DC Motor Speed Control Module will work. It is also possible to replace the variable resistor with your 0-5V signal.
Support Bennelson !
