Old 05-21-2009, 09:18 PM   #1 (permalink)
Christopher Jordan's Avatar
Gopher (aka- go fer...) - '95 Aspire 2dr hatch
Volts from heaven!
My batteries were low Wednesday, as expected since they do not hold a charge. I gave them a 3 hour charge to 13.6 volts and drove the rest of the day.
It was too late to charge them back up, and did not want to mess with the batteries Thursday; so the readings *should* have been low (11.5 - 12.9 volts). I never did charge it, but about an hour ago the meter read l4.7 to 15.0 volts on all 4 batteries!
I turned it off and on and checked the meter several times. No change. Very high readings like I just finished charging, but it is in my garage covered as always.
Any idea what happened? VERY hot batteries is scary! That was unusual.
Old 05-22-2009, 02:14 AM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Well you know sometimes neighbors and buddies will sneak over and put gas in a car if you brag about fe...
Old 05-22-2009, 12:27 PM   #3 (permalink)
faster Fiero
I once had a similar experience, come to find out the battery in my multimeter was very low, almost gone. I put in a new battery and the readings came back to normal.
Old 05-22-2009, 12:39 PM   #4 (permalink)
That makes sense to me. That external booster/charger has a meter for only the battery it is charging. This morning I will hook up each battery separately and see if they really are fully charged.
Memorial Day around here is a very bad day to find 4 dead batteries!
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
'97 Civic running 14.2 Volts? brucepick Off-Topic Tech 8 02-09-2009 11:31 AM
Bob Lutz talks about Chevy Volt's acceptable performance wikityler General Efficiency Discussion 2 09-27-2008 11:44 AM
7000 Volts DC RH77 The Lounge 5 05-26-2008 12:21 PM
