Old 06-02-2011, 12:03 AM   #1 (permalink)
VSS Correct, however mileage wrong.
Hi there guys,
I have already managed to calibrate the speed in accordance to my vehicle however the mileage is wrong in MPGuino.
I build my own PCB mpguino, however I used a 20Mhz crystal instead of 16mhz.
Is this the reason why my mileage is wrong in mpguino?
My ATMega328 was bootloaded on Duemilanove, and I saw the crystal on it was 16Mhz.
Old 06-02-2011, 12:16 AM   #2 (permalink)
Ohyeah, One more issue.
What is Current, Tank and Instant?
Old 06-04-2011, 12:58 AM   #3 (permalink)
Greetings. Are you saying the miles displayed on the MgGuino do not match the actual miles driven or are you saying the miles per gallon are wrong?
Old 06-04-2011, 03:01 AM   #4 (permalink)
I am using the canadian metric version version 0.81. It shows the vechicle speed as well as the mileage. However both doesn't tally. When the speed is correct, the mileage is wrong. When the mileage is correct, the speed is wrong.
Old 06-04-2011, 03:38 AM   #5 (permalink)
I am just another user but I can imagine the different clock speed could change the speed readout. As you probably know, miles or kilometers per gallon would be based on distance so and not speed so I think that is most important. Instant means mpg/kpg (liter) at that point in time, Current is mpg/kpg achieved on the current trip (you can change how many seconds it takes to reset the current trip if the engine has been switched off). Tank is mph/kpg since you last filled the tank. You can reset Current trip by pressing the center and the right button together and reset Tank by pressing center and left buttons together. By the way, pressing the right button step through the menus one direction and the left button steps through the menus in the opposite direction. These are just some things it took me a while to figure out. Norm
Old 06-04-2011, 09:24 PM   #6 (permalink)
Great! Thank you.
I might try a different clock speed to see if I can get the same speed readout.
