Old 09-18-2008, 09:27 PM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
LOL, no promises. what are the symptoms?
Old 09-18-2008, 09:34 PM   #32 (permalink)
testing the waters
It's pretty good, but I got 10 miles and it shows 9.8
and I'm sure it will get worse over time
but this mpguino keeps boogerin on me I can't keep it running long enough to get anything set up
when sleep mode kicked in, it wouldn't ever wake up, so I disabled it (though I left the screen = nil part, but I should fix that too). But my power connector had a cold sauder point and I fixed that and it runs better now, but it still won't act right sometimes it will restart after trying to play with it after getting in the car while it sits overnightalksdfjlksdaj
I dunno, I'll mess with it tomarrow
and then isolate the problems and let you know If i'm still confused
Old 09-20-2008, 11:58 AM   #33 (permalink)
dcb
needs more cowbell
dcb's Avatar
FYI, I added a setup parameter "VSS Delay ms", you can set it all the way down to zero by using the setup screen. left+right opens the setup screen. That's all I can do for ya with the information at hand.
VSS, tach, injector signal logic wikityler Instrumentation 2 07-20-2008 11:02 PM
Signal Generator dcb OpenGauge / MPGuino FE computer 26 06-27-2008 10:29 PM
Arduino-based turn signal jacket SVOboy Alternative Transportation 6 06-23-2008 10:22 AM
Opengauge/MPGuino development: Freeduino signal processing dcb OpenGauge / MPGuino FE computer 6 04-16-2008 09:40 AM
[CRXMPG Mailbag] SuperMID and VSS Issues with EF Civics SVOboy Instrumentation 0 02-03-2008 04:33 AM
