Old 09-17-2009, 12:25 AM   #1 (permalink)
VSS signal for GPS speedomoter
I'm currently working with someone online to develop a gps speedometer that will output a signal that will mimic a VSS. With a VSS output any aftermarket speedometer could be used as well as any aftermarket cruise control. I know there are drawbacks to using a gps as a cruise control device so none of the "that is dangerous don't do it" stuff. What I'm looking for is a recommendation on what kind of signal should the gps produce that would most standard. What would the voltage range be. Would it pulse high or low. and how long would the pulses be. These are the questions that the builder sent me and I don't know the answers as I've never messed around with a speed sensor before. Any help appreciated as I would really like to get this project off the ground.
Old 11-24-2010, 11:49 AM   #2 (permalink)
thefenixgang7's Avatar
Yammy - '78 XS750
90 day: 38.98 mpg (US)
Kawasaki - '82 KZ LTD
90 day: 45.94 mpg (US)
Jeep - '88 Cherokee Laredo 4x4
90 day: 16.42 mpg (US)
F150 - '90 F150 XLT Lariat
90 day: 13.67 mpg (US)
Did you ever have any luck?
How to Debounce a Geo Metro VSS Coyote X OpenGauge / MPGuino FE computer 19 07-26-2011 11:22 PM
What does an injector signal look like? mhopeng OpenGauge / MPGuino FE computer 10 12-28-2009 02:28 PM
VSS Signal assistance? dcb OpenGauge / MPGuino FE computer 32 09-20-2008 12:58 PM
VSS, tach, injector signal logic wikityler Instrumentation 2 07-21-2008 12:02 AM
Signal Generator dcb OpenGauge / MPGuino FE computer 26 06-27-2008 11:29 PM
