VW 1.6TD Engine Off Coasting
The service manual for my MK2 1.6TD VW states that damage may occur if towing on the drive wheels at speeds greater than 80kph/50mph. Does this mean engine off coasting above 80kph is harmful for the transmission? I thought only automatic transmissions see damage from engine off coasting. Is this transmission in particular incompatible with high speed engine off coasting? Or is engine off coasting normally not used at these speeds? I've pulsed and glided regularly between 70~110kph on this car for almost 2 years now...should I be concerned about transmission damage?
My guess is that the manual is in error, or didn't differentiate between the manual and automatic. However, don't hold me responsible for any damage that occurs. :p
i think it's rather for the safety of towing a car, as towing a car is generally more unstable at higher speeds. A manual box shouldnt give a damn
Or maybe it means that towing has not been tested above 80kph, so VW only ensures the safety up to that speed?
Mmm they specifically say it could cause damage to the gearbox. They also mentioned that automatics should not be towed on the drive wheels at all, so the advice for towing at 50mph/80kph+ is intended for manual gearboxes.
There is no restriction of towing speed mentioned when towing on the rear wheels, so this is related to the longevity of the gearbox, rather than the safety of towing at highway speeds (or whether they've tested it to ensure). |
I would be more concerned about shutting off your turbo engine hot, with the turbo spinning wild after your pulse :confused:
If EOC at those speeds would harm your gearbox, probably would have broken something by now.
How much you save fuel with EOC compared to coasting with the engine running? Just out of curiosity. |
I'm not sure how much the savings are. |
