Old 02-22-2009, 10:53 AM   #11 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Just another scheme to separate the rubes from their money.
You'd be able to give your vehicle the "basjoos treatment" for less money and you know the "basjoos treatment" works.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 02-22-2009, 11:48 AM   #12 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Originally Posted by jjackstone View Post
Actually if I recall, from MetroMPG's and other's posts, the alternator disconnect has been showing about a ten percent gain in overall FE. Please correct me if I'm wrong.
MetroMPG's car is so optimized he could go on a diet and loose 5 pounds and get a 10% improvement. His results in magnitude of improvement are not typical gains for an average car.
The TE generators do work but as has been stated are highly inefficient-- unless a newer technology has been released, they are generally between 3-5% efficient.
Doesn't matter what gear the vehicle is in, just the temperature differential between the "cold" side and the "hot " side of the junction.
Driving in first at high rpm is the best way to heat up the exhaust. The car is burning the most fuel it can in a given time and the engine is under the least load, hence the pistons are extracting the least power from the combustion gases and the hotter the exhaust gases.
Actually winding a car up in neutral at full throttle would be better for heating the exhaust but you would probably throw a rod.
Old 02-22-2009, 04:14 PM   #13 (permalink)
Does this mean thermoelectric exhaust generators as these, work better in cold climates?
Probably not a whole lot unless that cold air is directed to the TE junction. We're talking about temperature differentials of a few hundred degrees C in general(once the car is warmed up).
Alright, I'll give you that one, but I sure wouldn't want to be driving around in first gear all day
JJ
Old 02-22-2009, 05:24 PM   #14 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Tim: you're right, their figures don't add up. 600w production in highway use, yet they're claiming that offsets 30% of power needs. Which means the car needs 2000 watts to drive down the highway? Don't think so. Their figures need explaining.
Maybe the clue is "600 W(e)". What's (e)? I haven't seen that before.
The thing is that the output in city driving is probably a lot less due to lower average power output and a small difference in temperature. The 600W is probably max output on the highway with the average output around 100-200W.
The thing is alternator energy efficiency, like ICE energy efficiency, isn't linear AFAIK, which is why we're seeing things like dual-speed alternators, and the like. If this thermoelectric system can replace lightly loaded and inefficient alternator operation, then it could very well increase fuel efficiency by ~5% since the other 5% is when the alt is more heavily loaded and more efficient. It also depends on the manufacturer's alt operating parameters, which may be more efficient for a compact car that's focusing on efficiency light a Metro or Civic CX/VX as opposed to a car that focuses more on other stuff.
Old 02-22-2009, 08:41 PM   #15 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I don't buy it. It may get 600 Watts running flat out
This is just sensationalistic marketing hype.
What happened to this guys idea.
Johnson Electro Mechanical Systems
Anyway, There are already Chinese 250 watt per sq. foot thermjunctions for sale although they need a temp difference of about 400C & 25C to operate near that (never bought one, maybe they lie)
I agree with roflwaffle...
I would not doubt a 5% mileage gain, many alternators are not real efficient across their range; couple the belt and frictional losses that should be childs play to get a 5% increase with smarter alternator management.
Old 02-23-2009, 12:58 PM   #16 (permalink)
DieselMiser
ConnClark's Avatar
Okay here is the smell test on the 5% mileage improvement.
600W = 0.805HP
If it takes less than 17HP to operate a car the claims might be valid.
Note: This system only supplements the alternator and doesn't remove it.
Old 02-23-2009, 01:01 PM   #17 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Keep in mind the alternator is only roughly 50% efficient. So, in order to generate 600W, you need to generate 1.6hp.
Old 02-23-2009, 03:04 PM   #18 (permalink)
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
Nice work VW.
It always amazes me how these brilliant engineers pull a rabbit out of the hat every few years. Vehicles have come such a long way.
Old 02-24-2009, 02:30 AM   #19 (permalink)
DieselMiser
ConnClark's Avatar
Good catch. So that would raise the bar to 34 HP. However it forces the alternator to operate in its lower efficiency range which would reduce the net savings.
Old 02-24-2009, 01:20 PM   #20 (permalink)
rmay635703's Avatar
I have often wondered why the alternator isn't just cycled on when it would be at its most efficient range then cycled off when it won't be. Sure your battery would experience some small discharge/recharge cycles but I would think the efficiency gain would be enough to justify slightly lower battery life.
Perhaps its time for battery management on cars?
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 57 09-28-2011 06:41 PM
BBC reporter drives the new VW Polo Bluemotion 566 miles, gets 50 mpg (US) MetroMPG General Efficiency Discussion 1 04-08-2011 11:58 AM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
VW Produces 0.159 Cd, 235 MPG Car instarx Aerodynamics 8 03-02-2009 10:09 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 05:39 PM
