Old 02-25-2009, 01:53 AM   #21 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by ConnClark View Post
Okay here is the smell test on the 5% mileage improvement.
600W = 0.805HP
If it takes less than 17HP to operate a car the claims might be valid.
Note: This system only supplements the alternator and doesn't remove it.
For a car that size at an average speed of ~50mph, assuming city and highway travel, it would only need about half that in terms of power, probably less with more city driving and more with more highway driving. The bonus is that the output of this device scales with engine output.
Old 03-01-2009, 06:00 AM   #22 (permalink)
GreenMile - '00 Protege ES
90 day: 34.45 mpg (US)
I wouldn't compare watts to HP directly considering HP on an ICE is peak and doesnt translate directly to fuel consumption. Its a very rough comparison at best.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
Old 03-01-2009, 01:41 PM   #23 (permalink)
allc0re's Avatar
The Truck - '00 Ranger XL Ext. Cab
90 day: 24.94 mpg (US)
Send a message via AIM to allc0re Send a message via MSN to allc0re Send a message via Skype™ to allc0re
TEC CPU cooler
Here's a product that uses TEC. It' is the reverse of what we are trying to demonstrate here, but it does run on 12V, which is handy for vehicles. Can this be reversed to generate electricity rather than consume it?
Freezone Elite CPU Chiller
Old 03-03-2009, 06:34 PM   #24 (permalink)
Tracy - '00 corsa
actually 3-5% is quite efficient considering that the ICE itself is only 20%. i calculated the possible energy efficiency for a steam engine generator from waste heat and it was in the same ball park.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 03-04-2009, 12:18 AM   #25 (permalink)
TEC CPU cooler
The answer is yes.
JJ
Old 03-04-2009, 03:17 PM   #26 (permalink)
Automotive Xtremist
Turbalt - '09 Cobalt SS/TC
90 day: 37.98 mpg (US)
Bayou Blaze - '97 Blazer 4DR LT
90 day: 31.87 mpg (US)
TECs are terribly inefficient, but in quantity I don't see why they wouldn't work, any area where your temperature delta exceeds roughly 90 degrees will supply enough voltage under load to make a TEC worth it's salt in a car. But from testing your talking the best efficiencies of MAYBE 3-5 percent...most of it is lost to internal resistance...they however work better at colder temperatures, this is something that might be beneficial in the liquid cooling system...just food for thought.
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 66 05-22-2012 06:52 PM
BBC reporter drives the new VW Polo Bluemotion 566 miles, gets 50 mpg (US) MetroMPG General Efficiency Discussion 1 04-08-2011 10:58 AM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
VW Produces 0.159 Cd, 235 MPG Car instarx Aerodynamics 8 03-02-2009 09:09 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 04:39 PM
