Old 12-18-2009, 01:46 PM   #1 (permalink)
vw jetta wagon (can I install MPG gauge from V6 model in 1.8T model?)
I have a 2003 vw jetta wagon with the 1.8l turbo engine. I would like to put a mileage meeter on it that came from another model of the same car, the 6 cylinder version does anyone know if this is possible?
Old 12-18-2009, 03:10 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Where exactly is the mileage meter located? If it's in the cluster it might be as simple as a cluster swap, if you don't need to change any other electronics, but perhaps that's not it.
You could always pick up a scangauge, not stock but will give you more information with perhaps more ease.
Welcome to ecomodder
Old 12-18-2009, 05:10 PM   #3 (permalink)
I mileage meter is in the instrement cluster. I found some swap info on the vwvortex forum. thanks I am planning on a scanguage
Old 12-18-2009, 05:13 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Good stuff. When I drove the 09 jetta tdi I was pretty happy with the cluster mpg readout, just wish it would show more than one piece of data at a time.
Old 12-18-2009, 07:25 PM   #5 (permalink)
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
Lightbulb
Originally Posted by machineman View Post
I have a 2003 vw jetta wagon with the 1.8l turbo engine. ... another model of the same car, the 6 cylinder version does anyone know if this is possible?
Your best resource for a cluster swap, or how to configure your MFA readouts, would be TDIclub.com Someone there would know, or has already made a thread regarding which cluster features would be available on yours, and/or if a cluster swap is needed to get the output like you saw on the V6 equipped car your same model year.
Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
Old 12-28-2009, 11:56 PM   #6 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
module 17 19 re coding to match immobilizer
it is possible
BUT
the immobilizer coding will not match
module 17 and module 19 are both located in the cluster AND they must be coded to the car
or nothing in the car will function and the car will not start
that info will be available in VW Vortex also see RossTech regarding immobilizer
you will need to bring it to a shop that has OEM VW coding capability or a VW Audi dealer
VCDS will not do it on a 2003
2009 VW Jetta TDi Fuel Economy Review: 41.1 MPG SVOboy EcoModder Blog Discussion 3 12-19-2009 04:37 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 05:39 PM
