Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 02-02-2012, 04:23 PM   #1 (permalink)
VW Rabbit diesel pickup owner wondering about Brown's gas
I have several VW pickups, all diesel and all run.......... I dont use them much. The 83 gets 48mpg and the 81 only gets 42mpg. I have 1.9 trubo diesels in both. But the 83 has a 5speed and the 81 a 4spd. Has anyone tried H2O (browns gas) Generators?
Old 02-02-2012, 04:36 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
hi magicmanwon -
I moved your question into a separate thread. Maybe some of the diesel owners can chime in.
Old 02-03-2012, 12:09 PM   #3 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
Off to the Unicorn Corral with you. What's up with this rash of water electrolysis?
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 02-03-2012, 12:55 PM   #4 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
All HHO and Browns gas generators that run off your cars electrical system or off of any power generated by the engine are scams.
Scientific proof debunking the "run your car on water" scams
The Following User Says Thank You to ConnClark For This Useful Post:
Ryland (02-03-2012)
Old 02-04-2012, 06:16 AM   #5 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Don't waste your time and money on it.
There has been a lot of talk about it (search for HHO), but we're still waiting for a confirmed positive and verifiable result.
On the plus side :
Adding an easily combusted gas to diesel helps - it's been or being done with LPG, CNG, and H2 - as it reduces both the diesel and the total amount of fuel being used.
The total amount of fuel being reduced, means the diesel is burned more efficiently - there's also drawbacks to that, as higher temperatures lead to more NOx gasses in the exhaust.
The negative side :
You'd have to make the H2 and O2 gasses out of water by electrolysis, using electricity generated on-board by the alternator.
- the electrolysis device isn't 100% efficient, first loss.
- the alternator in your car isn't 100% efficient either, second loss.
- the engine driving that alternator, has even worse efficiency, greatest loss.
Result : any H2 you'd generate on-board, would come at a high energy deficiency. The beneficial effect of better / more complete combustion won't make up for the inefficient H2 generator.
I wouldn't add H2 to a diesel. It burns too hot and too easily.
But diesel+CNG is becoming more popular - though it comes at a price because of the CNG installation.
Not worth it on a vehicle from the 80s that doesn't see much use.
Have you considered switching to biodiesel ?
That'd reduce your impact significantly.
Lifetime fuel consumption :
Old 02-05-2012, 09:18 PM   #6 (permalink)
There's alcohol injection. With water/methanol injection, with proper tuning, you can see some fuel savings, but not enough to justify the kit. It's sold mostly as a power adder and a way to scrub carbon soot out of the combustion chambers and exhaust. And these are usually set only to come on at high boost or high load... injecting this at low boost / low load can have detrimental effects on the engine. I doubt this is what you're looking for.
One popular solution is diesel-propane injection... propane displacing about 40% of the diesel you use. Don't know about availability in the US. The nice thing is, propane is dirt cheap compared to liquid fuels, but this means you'll have to carry an extra tank in the pick-up. If the Rabbit diesel has an underslung spare tire, the tank can go there and you can stuff the spare behind the seats. (I do that with my two seat Sentra pick-up).
The economics only work out if you drive a hell of a lot, though. So this probably isn't for you, either.
Old 02-26-2012, 12:23 AM   #7 (permalink)
cool that you have multiple rabbits though
Old 02-26-2012, 06:51 PM   #8 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Water injection - EcoModder
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
