05-01-2011, 08:49 PM
VW Rims
Curious about wheel covers I found online. Are these the kind that only work in place of "hubcaps" I've only ever had "rims" (pictured below).
Thanks for expertise.
Look forward to hearing from some of you!
05-01-2011, 08:58 PM
Fairly sure they will only work with steel wheels.
regards
Mech
The Following 2 Users Say Thank You to Old Mechanic For This Useful Post:
05-02-2011, 10:53 AM
Thanks. I know this seems like an elementary question.
05-02-2011, 10:58 AM
Moderate your Moderation.
You can probably get some steel and cash to buy the covers in trade for your current wheels, if you really like the smoothie style.
05-02-2011, 11:41 AM
I do really like that and feel like that would help with my aerodynamics, but sheesh! that just seems like an awful lot of work.
I wonder how much more weight steel wheels are?
I also wonder if this would effect the resale value of my car?
:S
05-02-2011, 01:54 PM
Idiot Suv?? Sav?? Sev?? S
1]I wonder how much more weight steel wheels are?
:S
1] some steelie are less weight than the aluminum they replace.
2] yes, steelies are less value that "Rims". so save your rims and reinstall them when you go to sell the car.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
The Following User Says Thank You to metroschultz For This Useful Post:
05-02-2011, 01:56 PM
Steel probably is heavier by a good margin. You can sort of fix this by going to a smaller wheel with a slightly taller tire to keep the same circumference, but unless you drive mostly in the city, the impact will be minimal.
If you're worried about resale, go to the junkyard and buy a set of steel, clean them up and paint them, and keep your alloy around.
When you sell the car, the extra set of wheels will actually increase the take price, AND you'll probably keep the smoothies, so you can put them on the next wreck you buy.
The Following User Says Thank You to Christ For This Useful Post:
05-03-2011, 02:42 PM
Aero Wannabe
Some of us in snowy climates have our winter tires on extra steel wheels. You can buy new tires mounted on steel wheels at Tire Rack if you are going to a narrower tire size. FWIW, I have had trouble with some hubcaps, like the ones in your original post, coming loose. If you are getting junkyard rims, you could go with the aluminum racing disks and drill and tap the outside edge of the rim, and bolt them on. The tire bead covers and seals the holes.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
05-04-2011, 02:54 PM
#9 (permalink)
marcusmodder
I'm with COcyclist. The original Moon Eyes attach with small screws and fit on the alloys so you can keep the low weight. They are aluminum.
I have the hubcaps you posted there on my Previa and they are very thin and easy to dent. I have had to fix them a couple of times because the "Grip Tite Fasteners" weren't gripping very tight any more. They needed to be bent out a bit. That said, they are inexpensive and I have not lost any. I would buy them again though, at $60 a set they are worth it but if I had alloys it would be the Moon Eyes.
05-04-2011, 04:57 PM
#10 (permalink)
proof of concept
Perhaps you could fab up some temporary covers which would last long enough to demonstrate a mpg benefit or not,then make your decision based on results.
