Old 08-15-2017, 02:04 PM   #1 (permalink)
teoman's Avatar
A3 - '12 Audi A3
VW start stop hack
I am planning on purchasing a vw passat. I already have a passat that i bought for my mom (2010 1.8 TSI, 6.3L/100km my current average).
It has a dsg and i am fairly happy eith it except when parked on steep hills where it sucks. For my purchase dsg will not be a deciding factor unless the start stop feature can be hacked on the manual transmission so i can do engine off coasting. I searched the forum but was unable to find anything.
Has this been done before? Tjese cars do not really have a key anymore so it is not possible to switch the engine off
Old 08-15-2017, 08:25 PM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
For a normal petrol engine you'll be able to do the usual kill switch and bump start, but you'll also have to switch off stop/start at the same time.
P&G with EOC is for NA engines with low gearing. In a high geared turbo there's little point to it, and in some cars, it's actually worse.
I know the 1.2TSI shows around 0.4l/hr at idle (the 1.8 a bit higher obviously), so it's really not worth the effort of a kill switch, just use neutral coast.
Old 08-16-2017, 03:08 AM   #3 (permalink)
teoman's Avatar
A3 - '12 Audi A3
The 1.8 tsi consumes 0.8-1.2 l/h while idling.
I was thinking of getting the 1.6 tdi manual.
Old 08-16-2017, 05:12 AM   #4 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Would coasting down to stop lights etc be beneficial with the engine cut off in advance.
Just curious if it can be hacked, it should already have start stop.
Old 08-16-2017, 09:32 PM   #5 (permalink)
Team Turbocharged!
Pickups
If you simply kill the engine, stop start will try to restart it - if you run out of fuel for example, the engine will just keep cranking.
On a TDI I don't think you'll be able to kill the engine without a mass of warning lights and logged fault codes.
Old 08-17-2017, 12:51 AM   #6 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I wonder if the ecu can be hacked for this.
Old 08-17-2017, 02:10 AM   #7 (permalink)
ar5boosted's Avatar
Always. But in what way were you thinking exactly ?
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
Old 08-17-2017, 06:48 AM   #8 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Save the stop function activate at sat 30 kph while coasting down to a stoplight
Old 08-19-2017, 11:15 PM   #9 (permalink)
Team Turbocharged!
Pickups
Trying to automate functions that are best left manual is fraught with difficulty.
Diesels have so little engine braking that you may as well just DFCO to a stop. P&G is a thing for throttled engines, not diesels any way. You'll see better numbers just keeping in 'lean burn' than using P&G.
Old 08-20-2017, 06:59 PM   #10 (permalink)
ar5boosted's Avatar
Seems like a viable project to me. I'm a bit of a noob to car-hacking using computers but here is a good list of tools that I found so far:
- Car Hacking 101: Tools of the Trade | Make:
The Stop/Start system would be interesting to have even on non-vw cars. So whatever algorithm you came up with for that could be a generic template for other cars.
To me, I would pick gps based start-stop. Because many logic-assumptions would be based on things like distance to the next traffic lights and current speed, are you going up a known incline or down.
Yes, the Honda Jazz/Fit has that type of sensor in its gearbox already to read incline but what fun is that - especially if that is not your car.
I'm swaying to using a Raspberry-Pi for all this because of the higher-level software tools. Using pieces from the above link you could actually start implementing some of this soon.
Did I tell you I know OpenCV (computer-vision) programming ? you could detect a green light with a camera module especially if it's at a known point.
You can colour mask it to find out if it's green or red.
