Old 03-23-2009, 12:31 PM   #11 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by tasdrouille View Post
If not, there is a tsb for that and you can get repainted or new fenders from the dealer, even if it's just flaked paint and surface rust. The perforation rust warranty is also 12 years on those models.
I have a 2002 Jetta TDI I would like to unload but after storage it has a bad case of sheet peel on the front fenders, how do I get the Volkswagon dealer to replace or fix?
Or isn't this covered? When I went the dealer said it had to have a rust through hole of at least 3" before they would fix the problem?
Thank You
Ryan
Old 03-23-2009, 02:59 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Print the following and ask to see the service manager.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-24-2009, 06:32 PM   #13 (permalink)
rmay635703's Avatar
This time instead of saying its your fault and there must have been rock chips.
He actually looked at the car after I showed him those documents.
He kept saying the one side looks like rock chips and should not be covered, even after I told him it had been in storage when the sheet peel occured.
The other worse side he kept saying its hard to tell if this is from rock chips, then he asked if the car was in an accident which I said no, he said he thought it might be repainted though he could find no proof. He then took pictures which he said he would send to a higher authority to determine whether or not this would be covered under the corrosion warranty. He also took down the vin and serial and the number of miles on the car along with pictures of the dash and vin.
This is further than I got last time but it appears he isn't going to honor it under warrantee. More than likely he will ask his janitor how the weather is than calmly call me later and say that "his authority" doesn't think that the peeling paint is their fault and it must be my fault.
(at least thats what seems to happen around here)
Wish me luck
Old 03-25-2009, 07:21 AM   #14 (permalink)
Moderator
Technically he should send it for approval to the regional rep.
Old 12-03-2009, 03:46 PM   #15 (permalink)
I'd been looking for a good used TDI for years when I lucked out finding one for sale right down the street from where I live earlier this year. It was a 98, one lady owner, Jetta TDI with sunroof & only 82K. I was excited. A friend who owns 2 TDIs came over and drove it and all seemed good. I bought it for $3500. A few months later a friend was driving it when the clutch pedal went to the floor & stayed! Seemed like it was the clutch master cylinder to me but my Brazilian mechanic friend with not so good English (who's usually pretty good!) told me he was sure it was the clutch itself. So I bought a whole new clutch set and rear seal from TDI-Parts and had him put them all in for ca. $700+/- total parts & labor (cheap for a clutch job!) The old ones looked suspiciously good still. And wouldn't you know it, a month or so later, w/ no advance warning, it failed again in exactly the same way--I lost all clutch pedal. So this time I had the master and slave clutch cylinders replaced like I should have in the beginning. I took a summer road trip from Maryland all the way to the annual EAA Expo in Oshkosh WI and then on to Omaha NE to start my daughter in college. In Oshkosh my clutch failed again in the very same way! I drove 40 miles from Oshkosh to Appleton shifting all the way w/o a clutch (which I learned how to do driving VW bugs & vans in the 70s!) to a VW dealer there and paid $600 (including a rental for 3 days) to replace the brand new clutch master cylinder I had just put in! (It turned out to have been defective from the factory and I eventually got my $125 back for it!) In the meantime my TDI had been leaking oil like a sieve ever since my clutch job. It was clearly coming from the rear main seal that I hadn't noticed leaking before replacing it during the clutch job. The only obvious reasons were either my new rear seal was also somehow defective or had been somehow boogered during installation. Well, I've continued to drive it on several more road trips, most recently to Atlanta and back. It runs great. Gets 43-44 mpg at full hiway speeds and the oil leak is beginning to slow. But in the meantime I've noticed something else that alerts me to a more likely explanation for the cause of the oil leak. I'd noticed oil leaking around my oil cap for some time but stupidly didn't make the connection till recently. The oil cap gasket is still good but clearly oil is forcing it's way out. Then I realized the same was probabaly true of my rear main seal leak. It suddenly dawned on me that I must be have a bad ring or more, in one or more of my cylinders that was creating excessive pressure within my engine case (instead of just in the heads) which was forcing oil out thru the points of least resistance--my new rear main seal and oil cap. This is as far as I've gotten in my troubleshooting so far. Since it continues to run so well and the oil leak has slowed (but no way stopped) and I'm so cash strapped--I'm delaying having a very expensive ring job done. Am changin my oil more often to compensate for accelerated oil contamination thru blowby down into my case. Would appreciate any words of wisdom from anyone that reads this and has any words of experience or knowledge to share.
Thanks a lot...! -Larry
Old 12-03-2009, 05:24 PM   #16 (permalink)
Moderator
That's weird. These engines usually have a lot of blowby but that is usually not a problem unless somehow your CCV puck on the valve cover is plugged. I'd advise you to head over to TDIclub.com and search for your problem there. Also, you should take your TDI to a proper TDI mechanic in the future. There is a list of TDI gurus over at TDIclub.com which will point you to the right person in your area.
VW TDI vs. Gas comparison guudasitgets General Efficiency Discussion 99 11-27-2009 08:12 PM
VW Lupo crash tested by the NHTSA tjts1 General Efficiency Discussion 19 07-02-2009 07:18 AM
FS Silver TDI Corrado with Black Leather 100% Diesel Conversion with Origninal Paint G60ING For Sale 8 03-09-2009 12:34 AM
FS: 1996 VW Passat TDI G60ING For Sale 0 02-26-2009 07:12 PM
New USA Energy Policy NeilBlanchard General Efficiency Discussion 18 11-17-2008 12:54 PM
