Old 08-10-2012, 12:07 PM   #11 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
92 93 94 95 Honda Civic Ignition Switch Wiring NEW | eBay
read what it says next to the price (more than 10 available, [B]323 sold[B])
read the description of the part for further info. on mine i was able to transfer the wire that lets you know the key is in the ignition no big deal just have to pull the wire in out the back of the connectors
Old 08-11-2012, 01:10 PM   #12 (permalink)
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
I went through the testing found on this site..
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
It was very helpful to me even though it was for an Integra because of all of the pictures. For some reason I could not get the coil to test out correctly and replaced that first but it was not the problem. I went through the ICM tests and that turned out to be the issue. Thanks to everyone for the assistance. I learned a lot!
Old 08-11-2012, 10:58 PM   #13 (permalink)
scivicblu83's Avatar
experimental - '90 honda crx hf
90 day: 67.81 mpg (US)
cool! glad you got your car running again. by the way civics And integras are almost the same car under the skin, as were accords and preludes. how much was your module?
Old 08-12-2012, 09:38 AM   #14 (permalink)
It was $100 at Autozone. I saw that Rockauto had them for around $60 but I couldn't wait. Hopefully the Duralast will last.
Old 08-13-2012, 07:29 AM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Excellent. And it might have been the coil that destroyed the ICM, anyway, so there you go... Congrats.
civic vx
