Old 09-16-2009, 06:29 PM   #1 (permalink)
VX swap questions
I have a 1974 Honda Civic which I made AWD by transplanting it onto a shortened 1989 Civic RT4WD floorpan/firewall (OBD-0 chassis). I've driven it over 100K miles since the transplant, with two different engines. Right now it is running a 1994 OBD-1 d15b from a JDM civic. I only get 30 mpg, which is a disappointment. I used to get 31-32 with the original non-vtec d16a6.
I picked up a cheap VX (d15z1?) motor from a guy who swapped it out for more power. What is needed to get the VX up and running in stock form? I've already got an OBD-1 jumper harness, I'm running an OBD-1 P28 ECU now. I've got the 4 wire O2 sensor. I've heard there is some component that needs to go on the firewall, or something, that is specific to the VX. I don't yet have an ECU.
Brian
Old 09-16-2009, 08:28 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
A p28 and 4-wire isn't going to work for the car, unless you're planning to run california emissions, in which case you'll probably still need a cali vx ecu since I don't think anyone has dumped the rom for the cali vx yet. I would pick up a p07 and ntk/ngk 5wire or the swap really won't be worth it. You'll also need the additional wiring for the vx and the EGR controls.
Old 09-18-2009, 05:34 PM   #3 (permalink)
I meant that I have a 5 wire, not 4. My mistake. What extra wiring? Are you sure the VX has an EGR? Is the P07 the stock ECU? Is there a difference in the long block for a CA VX vs. 49 state VX? Or is it all external?
Old 09-18-2009, 06:25 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Extra wiring would be vtec, egr, 5 wire o2, I'm not sure if there's any besides that if you are already running mpfi.
I'm sure it has egr, I can show you a picture of the egr valve on my engine if you want me to.
P07 is the stock ECU
The differences are just the o2 and computer.
Old 09-18-2009, 06:44 PM   #5 (permalink)
I'm already running OBD-1 vtec so I think it is just the 5 wire and the EGR, right?
Old 09-18-2009, 06:45 PM   #6 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
that is a strange car
Old 09-18-2009, 07:52 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Probably, yes. I forget from when I did the swap but that seems about right
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
VX final drive swap: Who to believe? Cleft_Asunder EcoModding Central 28 01-28-2009 10:17 PM
have some questions about a vx or hx swap soj8888 EcoModding Central 3 07-25-2008 12:54 AM
VX swap questions reformed EcoModding Central 7 03-05-2008 09:24 AM
