Old 06-11-2009, 11:39 PM   #1 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
Lightbulb WAI vs Ram Air Intake --- at speed...
I think that a Ram air intake would be BETTER (even though obviously at outside air temps) than a WAI at speed.
Why? Because the extra pressure would decrease losses in the intake manifold.
Kind of like this,
and pointing STRAIGHT into the air intake through one of these air filters
<-pretend its an air filter I couldnt find pictures of closed inline air filters
and STRAIGHT into the throttle valve...
I know, very theoretical to have everything STRAIGHT... but such is the case in my 350z...
Old 06-11-2009, 11:52 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
There are formulas online for figuring the efficacy of ram air.
And this: Interesting autospeed article on ram air intake
And google "autospeed ram air" cuz they've done lots of piddling around with it.
Old 06-12-2009, 08:24 AM   #3 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
In general, anything that increases the amount of oxygen going through the engine also increases the amount of gas burned since the engine controller adds gas in proportion to the amount of oxygen it detects in the system. WAI reduces the amount of fuel burn by reducing the density of the air entering the engine and reduced air density contains a reduced amount of oxygen in it, producing a FE improving effect identical to that of driving at an higher altitude. A ram air intake increases the air pressure and density of the intake air, acting as a sort of mild super/turbocharger (without the engine load of the latter), and so would increase the fuel burn.
When hypermiling you spend most of your time at low throttle settings where the throttle plate is mostly closed and is by far the biggest intake restriction.
Compared to the throttle plate, other parts of the intake air path contribute little to the intake manifold losses when running at low throttle settings.
aerocivic.com
Old 06-12-2009, 12:32 PM   #4 (permalink)
Ram air is definitely the way to go for FE. The more air you can stuff into the intake without consuming extra energy, the less work your engine will have to do breath in. Its pretty simple. Also the colder the air the better. Check out all the autospeed articles on the subject. This has been proven over and over again.
EDIT:
I'll cut and paste the articles here from the dead thread for easy access.
HAPPY READING
Eliminating Negative Boost - Part 1
http://www.autospeed.com/cms/A_0629/article.html
Eliminating Negative Boost - Part 2
http://www.autospeed.com/cms/A_0637/article.html
Eliminating Negative Boost - Part 3
http://www.autospeed.com/cms/A_0646/article.html
Eliminating Negative Boost - Part 4
http://www.autospeed.com/cms/A_0652/article.html
Eliminating Negative Boost - Part 5
http://www.autospeed.com/cms/A_0663/article.html
Negative Boost Revisited, Part 1
http://www.autospeed.com/cms/A_107824/article.html
Negative Boost Revisited, Part 2
http://www.autospeed.com/cms/A_107825/article.html
Negative Boost Revisited, Part 3
http://www.autospeed.com/cms/A_107826/article.html
Negative Boost Revisited, Part 4
http://www.autospeed.com/cms/A_107827/article.html
Negative Boost Revisited, Part 5
http://www.autospeed.com/cms/A_107828/article.html
Doing the Impossible
http://www.autospeed.com/A_109877/cms/article.html
Modifying the VL Turbo Intake
http://www.autospeed.com/cms/A_0779/article.html
Into the Intake - Part 1
http://www.autospeed.com/cms/A_1361/article.html
We Have a Record!
http://autospeed.com/cms/article.html?&A=109217[/QUOTE]
Ram Air Project
http://www.karlsnet.com/mopar/ramair.shtml
Old 06-12-2009, 12:35 PM   #5 (permalink)
doviatt's Avatar
Grey Goose - '89 Metro LSI 4 door hatch back
90 day: 59.36 mpg (US)
I sense a contradiction. ???
FE not power.
Old 06-12-2009, 12:42 PM   #6 (permalink)
^I know, because the air is less warm it would be lower FE.
BUT because it lowers the pumping losses it would raise FE (and more than the cold air takes away) yielding a net increase in FE.
Old 06-12-2009, 12:46 PM   #7 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Now, here's a question:
What if you warmed up a ram air intake? Could you warm up a ram air intake? You get warm dense air with more pressure?
Or is it simpler to just modify the throttle plate?
Old 06-12-2009, 12:47 PM   #8 (permalink)
doviatt's Avatar
There are some good points here. I've got some reading to do on autospeed.
Old 06-12-2009, 12:53 PM   #9 (permalink)
That is where I was going with this. IF ram air helps, and WAI helps, then why not both?
Maybe construct a ram air of metal pipe and run the coolant hoses around it to heat it.
Now my question is, how much positive PSI acts on a car's front bumper at 60-65mph? Anybody know?
Old 06-12-2009, 01:01 PM   #10 (permalink)
Ram air is not matter of PSI. The goal is to reduce the pressure loss that happens inside in the intake ahead of the throttle plate due to its geometry to zero. If you wanted warm RAM air you can just setup a very large intake behind the radiator. But you would be wasting your time.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
