Old 07-20-2010, 11:07 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
thecheese429 has blazed the trail on "aftermarket" vss here:
fabricating a VSS?
re: abs sensor, definitely maybe.
Old 08-13-2010, 11:21 AM   #12 (permalink)
What about the old add on MPG computer and cruse control sysyem??
It takes a small coil and a pair of magnets on the drive shaft?
I understand you can make the coil by takeing the coil out of a 12 volt relay.
Rich
Old 08-13-2010, 12:41 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
the coil doesn't make a sufficient signal at low speeds.
Old 08-13-2010, 12:45 PM   #14 (permalink)
Well the one on my old Mileage computer worked fine down to 1 MPH...
I know the cruse controls were program not to work lower than say 30 MPH and many would drop out at over 80 MPH, but the speedometer always read.
Rich
Old 08-13-2010, 12:47 PM   #15 (permalink)
Also we could double the magnets for a finer reading and more signal...
Rich
Old 02-07-2011, 08:26 PM   #16 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
At last, I got a VSS rigged up on my truck. The factory VSS did not provide a signal that would trigger the MPGuino. After much trial and error, several attempts at trigger disks and lights, I have a working solution.
I used a piece of black corroplast, cut to about a 5 or 6 inch diameter disk. I then cut it from the edge to the center just so I could slip it over the driveshaft. I then made small cuts from the center, probably 8 in total counting the first long cut. I then cut 4 rectangular windows about an inch in from the outer edge, spread evenly around the disk. Any more and I didn't think the light sensor would do a good job picking up the signal. To clamp it to the driveshaft, I used a hose clamp. Had to reposition a few times to try to get the disk clamped evenly, and rather straight. I also had to run a zip tie to straddle the long cut I made, and looped it through the two closest holes to cinch it together a little more evenly.
I am using an ordinary cockpit gauge bulb, 12v, as the light source. It is hard wired into the cigarette lighter circuit, which is a switched 12v supply. The light sensor is an IR sensing LED from Radio Shack, p/n 276-145A NPN Silicon Infrared Phototransistor. I tried using phone cord for wiring, but ran it too close to the exhaust and had a meltdown. I have since replaced that with CAT-3 wiring, which has 6 wires instead of 4, and they are solid conductors, instead of braided. Worked better for me when positioning and soldering. I used 3 (red, black and green) for the light and sensor. Both share the red, the bulb uses the black as ground, and the sensor uses green to go back to the MPGuino...and to ground.
Installed pictures attached. Sorry, it is nighttime, and I used my phone. If needed, I can provide better pictures later.
And...ops checked good! Got the VSS signal set to 19360. 4 slots in the disk, 33 inch wheel/tire combo, and 5,280 feet in a mile. I will still keep eye-balling the fuel flow, as I have been driving that way for a year now.
The Following User Says Thank You to ECONORAM For This Useful Post:
dcb (02-08-2011)
Old 02-08-2011, 11:27 AM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
Homemade optical speedo signal FTW
Old 02-09-2011, 08:34 PM   #18 (permalink)
Discovered one issue today. With a fresh coat of snow on the roads, the sensor wouldn't trigger the MPGuino. I figure the sun was reflecting enough light to mask what the bulb was putting out. When I hit a clear patch in the road, it'd pick right up again. Guess I need to stick that belly panel back on...
vss sensor speedometer
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
High speed motor wanted henrikga Motorcycles / Scooters 3 10-11-2009 07:19 AM
