Old 07-14-2011, 02:01 PM   #1 (permalink)
katiep's Avatar
Red - '04 Aveo
90 day: 35 mpg (US)
warm weather and MPG - HOT weather and MPG
So yes, we get better FE in the summer and it decreases in the winter. But, when it's Africa hot outside, does FE suffer? Does it get outside the range of helpful for FE? My car has started feeling like it's working a bit hard since the weather got above 95 degrees. It's also never in a covered place. I park in the shade when I can get it, but that's not often, during the day. I would guess the radiator fan is running a lot, but I'm not sure. I'm planning on putting a light in with the relay one of these days.
Old 07-14-2011, 05:09 PM   #2 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I haven't noticed an upper limit.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
Cd (07-15-2011), dennyt (07-14-2011)
Old 07-14-2011, 07:39 PM   #3 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
91.5 MPG on my 99 Rebel today. Actually cool here today with a high of 81. Going down to 64 tonight. Beats last years max of 109, but it ain't over by a long shot.
regards
Mech
Old 07-14-2011, 09:51 PM   #4 (permalink)
I would think any loss in fuel economy as you get in the super hot region would be due to increased A/C usage. All fluids get thinner as they get hotter and the engine pumping losses are less in the heat. The air you are pushing should be thinner too.
Old 07-14-2011, 11:52 PM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...also, the hotter it is to start with, the "quicker" everything (coolant, oil, etc.) gets up to 'normal' operating temperature(s) and so you reach max.mpg sooner.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 07-15-2011, 09:28 AM   #6 (permalink)
Indeed. If I drive home for lunch, the back-to-work trip is usually +10 mpg from normal due to being warmed up.
Old 07-15-2011, 01:21 PM   #7 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
No upper limit in my truck. I can get 30 MPG to and from work when temperatures are in the mid 80's or higher.
Old 07-15-2011, 09:48 PM   #8 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
I don't see an upper limit either, except, as you mentioned that the fan would run more.
Usually the biggest problem is that the driver gets overheated, cranky; and not as attentive, with less patience to drive their best.
I'm still waiting for summer here! We've had maybe 3 days in the 80's at all so far. Sometimes, it's still a wait for the 70's!!!!
Old 07-19-2011, 04:23 PM   #9 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Frontier XE
90 day: 27.72 mpg (US)
I agree, the only negative factors in high temperatures are:
-A/C usage (a huge decrease depending on your car)
-Slightly more rolling resistance due to softer tires
-Possible fan loading if engine temps get too high
-summer blend fule
Overall, between air density and fluid viscosity, heat is better than cold hands down for FE, that is assuming you sweat it out with your AC off and widows up!
Old 07-20-2011, 09:54 AM   #10 (permalink)
Correct on the AC and Fan items.
- Summer blend fuel is usually better than winter blend.
- Rolling resistance is better in heat and worse in cold. (The Recumbent Bicycle and Human Powered Vehicle Information Center)
