Old 02-10-2012, 11:59 AM   #1 (permalink)
Yotarolla - '06 Corolla ce
90 day: 42.98 mpg (US)
warmer fuel?
I was reading an article that mentioned this: "the fuel line was insulated and heated so the gasoline entered the combustion chambers as lean vapor."
I hadn't heard that before. Anyone have experience with this?
Old 02-10-2012, 12:10 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...sounds like the prelude to "...vapor lock..." conditions.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 02-10-2012, 12:21 PM   #3 (permalink)
Background info: this was a technique used to win the 1973 shell mpg competition. It was a modified opel, achieving 376 mpg at 30mph.
Old 02-10-2012, 12:52 PM   #4 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
Link or it didn't happen!
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 02-10-2012, 12:58 PM   #5 (permalink)
Now that I have more than 5 posts, link...
Souped Down 1959 Opel T-1 Gets 376.59 mpg : TreeHugger
The Following User Says Thank You to k-vette For This Useful Post:
Olympiadis (02-10-2012)
Old 02-10-2012, 01:15 PM   #6 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
Surfacant:
Surfactant - Wikipedia, the free encyclopedia
While it's technically not a surfacant, heat energy has a similar effect by lowering surface tension. This improves both atomization and vaporization.
Gasoline is made of a variety of hydrocarbon molecules with a mix of vaporization temps. Some of them do not flash vaporize until the temp reaches around 400*F. The problem is that many of the hydrocarbons will flash vaporize at temps well under 200*F, so that problems like vapor-lock will pop up unless contingency measures are taken against it.
The main point is that some heat does help, especially in situations where atomization or vaporization is poor. This is common with wet-flow induction systems (carburetor & TBI), and in very cold conditions.
A fuel system under high pressure can handle more heat, but don't forget about your fuel vapor recovery system. Heating the fuel can overwhelm the vapor control/recovery, so again contingency measures have to be taken to handle the extra vapor from the tank.
MPFI with the injector spraying on the back of the intake valves will show the least improvement from heating the fuel. That's not to say it doesn't work at all, but every system responds slightly differently, so you'd have to try it out and then decide if it's worth the trouble.
Old 02-10-2012, 01:20 PM   #7 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Originally Posted by Olympiadis View Post
[B]
ummm you don't want to heat the tank just the lines to the injectors that way the is no effect on the vapor control/recovery system..
Old 02-10-2012, 01:49 PM   #8 (permalink)
The problem is for many fuel injected vehicles, they get fuel pressure off a common fuel rail maintained at X pressure. Any fuel not used gets returned back to tank from pressure regulator return line (which ends up being most of the fuel ).
So its hard to heat fuel after rail (between injector and fuel rail ) as there no room with injector mounted right into rail .
Honda does not use return line on fuel rail, they have pump and fuel regulator in gas tank and run constant fuel pressure over the whole load . So with only 1 fuel line to rail I could see this being warmed up a bit (water warmer off heater core line) but not sure how much this would help with modern injectors as noted in above posts .
Old 02-10-2012, 01:56 PM   #9 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I believe all gasoline vehicles since OBDII (1996) have gotten rid of return style fuel systems. I believe the change came because it reduces evaporative emissions.
Old 02-10-2012, 02:17 PM   #10 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Transonic Combustion | Ultra-high Efficiency Fuel Injection Systems
regards
Mech
