Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-18-2008, 12:29 PM   #11 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
My dryer has a setting that you can choose how 'dry' you want your clothes and then it automatically turns off, a lot better than setting a timer. Clothes rarely, if ever, need to be washed in hot water. I'm still trying to convince my wife that she can wear some things more than once without washing them and the clothes will not disintegrate. Mostly jeans, which take the longest to dry.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-18-2008, 12:58 PM   #12 (permalink)
http://us.lge.com/products/model/det...WM3431HW.jhtml
That is not the exact one I have but it works the same way. Instead of a vent, it uses a compressor (like the ones used in air conditioners) to compress a gas (commonly chlorodifluoromethane, also known as R-22), getting it hot. The hot gas flows through a radiator (condenser) that allows it to give up heat to the air stream that dries the clothes. In the process, the gas loses so much heat that it condenses into a liquid. A control valve (TXV) lets some of that liquid flow into another radiator (evaporator). As the pressure drops, the liquid boils and takes in heat from the air stream leaving the clothes, causing the moisture to condense for removal. The air is recirculated through the condenser for reheating, and the gas from the liquid boiling off is returned to the compressor.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 09-21-2008, 09:48 PM   #13 (permalink)
I made a second hole so that in the winter I can pipe my dryer exhaust into my house instead of outside. The boost of warm, moist air is really nice. Why just throw it away?
Also, I have a rather old dryer that only runs by a timer and when I actually experimented to see how long it took to dry things, I found that I had been drying too long for years.
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
Presidential Candidate Views On Auto Energy Conservation Matt Herring The Lounge 2 09-06-2008 12:48 AM
Energy Program in Texas Lazarus Saving@Home 5 08-08-2008 12:24 AM
Monitoring tools cut home energy usage SVOboy Saving@Home 5 01-11-2008 12:00 AM
