Old 10-02-2008, 07:44 AM   #31 (permalink)
I have seen plenty of sterlings and Tesla engines screaming on you tube but I have not ever seen one running an alternator or a generator. If you have seen this then put a link up. Make sure they are showing their results. Amps, volts, ect......
Old 10-02-2008, 09:24 AM   #32 (permalink)
Tracy - '00 corsa
Originally Posted by Big Dave View Post
What you describe is called compounding.
Compounding can indeed increase eficiency. The old B-29 engine (R-3360 I think) and the Napier Sabre were some of the most efficient engines ever built.
Compounding works well (with some reliability issues) at high engine load, but has no scope for contribution at the low loads used by us MPG seekers. Consider turbo lag. A tirbocharger is a form of compounding where the waste heat engine (the turbo) drives a centrifugal compressor. At a low gas flow and heat rate, the turbo makes almost no boost. At high gasflow rate(high RPM) and high heat rate, it works well enough to require a wastegate to prevent overboost.
For a car, with its very light duty cycle to be able to use compounding the main engine would have to be so underpowered as to be running at high load a high percentage of the time. It ain't worth the effort on a high-MPG car.
so you mean if the engine is propperly sized for the load, like a car that mpg seekers would buy, then it would work. of couse its worth the effort. on the highway my 1.0L engine is at 70% load (estimate) at 60mph.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 10-03-2008, 12:38 PM   #33 (permalink)
33%
Originally Posted by elhigh View Post
You're driving something that's 33% efficient? I'm not willing to believe that.
Last I heard, the best gasoline engine out there was only 20, maybe 25% efficient at its very very best. Diesels, by nature of their combustion cycle, are a little better.
I could be wrong - I'm remembering from ten years ago and I haven't heard anybody give an efficiency rating since then. Then again, my ride is older than that and so are a lot of other folks' cars.
I'd give body parts to hit 33% efficiency.
That's the chemical release energy in Btus before any mechanical losses.About 66% of your fuel's energy goes out the tailpipe, or is lost to the cooling system.Some automobiles have efficiencies less than 20% overall.
Old 11-21-2008, 09:40 AM   #34 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Some more news on the waste heat recovery front:
Waste Heat Recovery System Receives Powertrain Innovation of the Year Award
The Paris, France-based developer of a waste heat recovery (WHR) system, heat2power, won the Powertrain Innovation of the Year Award at the Professional Motorsport World Expo in Cologne (11-13 November) with its Thermal Energy Recovery System (TERS). heat2power says that its WHR system can provide fuel savings of 15-35% under all driving conditions at a cost of approximately 30% more than a comparable turbocharged gasoline engine.
Source: Green Car Congress: Waste Heat Recovery System Receives Powertrain Innovation of the Year Award
Old 11-21-2008, 11:42 AM   #35 (permalink)
dichotomous's Avatar
CivySi - '03 civic SI
90 day: 31.99 mpg (US)
I want to do this but I'm annoyed because I just bought a new raceheader and I dont wanna see that as a waste of money.
though, removing everything on the accessory belt and the crank pulley would sure free up power and let the engine use almost no power at idle. imagine the easy low RPM driving with no accessories on the motor....
Old 11-21-2008, 12:31 PM   #36 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
[...]at a cost of approximately 30% more than a comparable turbocharged gasoline engine.[...]
Looks like the cost will be highly prohibitive, which probably limits the tech to high markup vehicles. It's still a good thing for fuel conservation as a whole.
www.HyperKilometreur.com - Quand chaque goutte compte...
Wood stove radiant heat!??! bennelson Saving@Home 28 07-29-2010 11:39 AM
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 06:03 AM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 12:30 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
