Old 07-08-2009, 06:24 PM   #11 (permalink)
CobraBall's Avatar
Try a bottle of RXP. RxP Main Menu Tune up your engine with RxP Gas Kicker. RxP removes carbon build-up from your engine. This restores lost power, improves fuel economy and significantly reduces emissions. If you want your engine to run like it did when it was new, add
Photos Piston before and after WELCOME TO RXP PRODUCTS, INC. THE HOME OF THE LITTLE RED BOTTLE
The science behind it. This IR radiation is absorbed by the filter that RxP provides to the fuel mixture and this mixture is preheated prior to combustion. Thus the temperature of the combusted gas is obviously higher, but also the chain reaction (combustion) is promoted s
It can/does overcome the crappy federally mandated gasoline/corn brew.
Old 07-09-2009, 05:48 AM   #12 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Originally Posted by wwelder View Post
It's a '94 metro 1.0 engine with no pre-existing problems. Carbon build up seems to be a problem with this particular engine that I am trying to head off.
I change oil every 7K....use a pint of water in the intake thru an old dish soap bottle...keeping the revs up around 2K. Then add 1 pint kerosene to the oil...run at fast idle for 15 mins...then new oil and filter.
If you use a fuel additive like acetone or iso or ??...you can improve combustion and reduce carbon buildup.
Old 07-09-2009, 11:42 AM   #13 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I'm not even touching this...
Old 07-10-2009, 05:55 AM   #14 (permalink)
What? Chicken?
Old 07-10-2009, 12:30 PM   #15 (permalink)
Steve - '92 Festiva
What? Chicken?
Nah, I prefer Pork.
Old 07-10-2009, 06:27 PM   #16 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
I ported and polished my intake tract by running sand through my engine
http://www.audiforums.com/forum/show...t=80267#693578
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 07-10-2009, 06:29 PM   #17 (permalink)
Steve - '92 Festiva
You too? I got a welded diff.... beat that!
Old 07-10-2009, 06:37 PM   #18 (permalink)
Manic Rabbit
Southcross's Avatar
I change oil pans ever 10k miles
-Edward
Goal: 4x / 5x
Old 07-10-2009, 06:45 PM   #19 (permalink)
Steve - '92 Festiva
Nice. UR Teh WInRar.
--- Water injection VS Steam Injection --- basslover911 General Efficiency Discussion 96 05-22-2012 05:09 PM
Run Your Car on Water!!! (emulsion that is) Coyote X EcoModding Central 17 04-01-2009 01:20 AM
DIY - Water Injection Stormin' Norman DIY / How-to 45 02-05-2009 04:42 AM
Water Meter for water savings!!! bennelson Saving@Home 3 12-11-2008 07:21 PM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 10:02 PM
