Water Injection?
I'm thinking of implementing water injection as seen here:
Mother Earth Alcohol Fuel: Ron Novak's Do-It-Yourself Water Injection System I have a 2004 Silverado 4.3L (Vortec) Wondering if I would see any change or benefit from this. |
Been looking around some more and saw something on Gas Vaporizing...
http://www.youtube.com/watch?v=_Uin3hTJC30 Is this legit? |
First, lookup (GOOGLE) what 'high humidity' (water-vapor) does for/to internal combustion engine operation.
Then, lookup purpose & effects of 'water-methanol injection' used in WWII aircraft engines. Finally, draw your OWN conclusion(s). |
could you clarify??? I've never heard of anything bad about water injection, but then I'm only aware of water/methanol injection systems. And those are usually for FI car, not NA!
Again, couldn't find anything about how "bad" water/methanol injection is ...
LOTS of details about diesel and gas FI cars benefits though! Water-Methanol Injection: How Much is Too Much? - Diesel Power Magazine Benefits of Water/Methanol Injection: Engine Builder I never really looked into ALL the details but I can't find details on the dangers for the engine internals anywhere! |
I've found information to the contrary:
Patent US4289508 - Device for filtering and for humidifying the admission air of an internal ... - Google Patents You can download the Patent if you want. |
And another one I found...
Patent US5065704 - Internal combustion engine and kit therefore - Google Patents |
Snow Performance : Snow Performance Water Methanol Injection Systems. The Best Most Accurate Gas and Diesel Water Methanol Injection Strategies for Fuel Injected Carbureted Turbocharged Supercharged
Snow manufactures a system that works very well. Dyno testing performed on "Horsepower TV" was amazing. |
...there are literally 1,000's of Patents on useless concepts, impractical things, and questionable ideas.
...an earlier posting on this "water" subject: http://ecomodder.com/forum/180860-post10.html ...just for "fun" run though the numbers with RH = 100% and see what you get/need. |
