Old 11-03-2009, 02:19 PM   #11 (permalink)
Originally Posted by Rokeby View Post
(Thinking of a Wankel's wipers/seals.).
The Wankel was the first thing I thought of when I looked at the illustration. It looks to be a quasi two-stroke quasi-turbine type of thing, much the way I view the Wankel engine.
-soD
Old 11-03-2009, 02:40 PM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I personally wouldn't categorize a wankel as a two stroke, it sucks and squeezes and bangs and blows like a 4 stroke (you can follow the air charge clockwise from the upper right).
Old 03-22-2011, 09:24 AM   #13 (permalink)
DocRings
docrings's Avatar
GS400 - '00 GS400 Platinum Edition
90 day: 23.41 mpg (US)
Mojo - '97 Pyzar Moon
90 day: 26.25 mpg (US)
Silver Bullet - '02 Insight
90 day: 61.62 mpg (US)
New Video Link:
Lot's of news out this month...with what looks like a working prototype on the stand in the lab (and a model in his hands).
The Following User Says Thank You to docrings For This Useful Post:
NeilBlanchard (03-22-2011)
Old 03-22-2011, 10:02 AM   #14 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Shock wave puts hybrid engines in a spin - tech - 15 March 2011 - New Scientist
Old 03-22-2011, 10:19 AM   #15 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
What's messing me up is at #4; the intake and exhaust for the chamber are uncovered at exactly the same time... one would think that in order for it to work the exhaust would only flow to the outside and the intake come into the chamber... but I presume the exhaust is under far higher pressure, because it has to be, because it didn't expand at all in the "chamber". So then in order for the intake to displace the exhaust as pictured, and the exhaust to do any useful work on blowdown, there has to be hella centrifugal force throwing all the gasses to the outside...
dcb (03-22-2011)
Old 03-22-2011, 09:11 PM   #16 (permalink)
Josepha - '08 xD
The two eye shaped bits near 1 is stationary, and the intake comes in through 1. Both the sides are exhaust. I think.
Old 03-22-2011, 11:56 PM   #17 (permalink)
Bookworm
fjasper's Avatar
Sylvio - '02 allroad quattro Biturbo 6-spd
90 day: 19.84 mpg (US)
Whitey - '88 80 quattro
90 day: 26.84 mpg (US)
Bertie - '99 Miata
90 day: 30.27 mpg (US)
Kate - '03 Katana 600
90 day: 40.83 mpg (US)
"All the presented below results correspond to the case of heat release
steam equal 800 W and disk rotational speed equal 176 500 rpm.
The rotational speed sounds crazy, but it's not outside the realm of operation for turbochargers. Plus, it's fast enough for foil bearings to work, and they're just cool.
Old 03-23-2011, 12:11 AM   #18 (permalink)
DocRings
docrings's Avatar
Both sides are exhaust...correct. The force from the gas expansion seems to push off the rotor and give the push to keep the spin going.
I wish I knew what the ignition source is... a constant spark fixed to the wall? What kind of tolerances are between the rotors and the outside walls, that prevent gas blow-by? Is there room for more efficiencies with rotor shape changes, exhaust outlet configurations, inlet directional vanes, timing changes by moveable fixed walls/ignition timing, etc.? Does the inlet fuel/air charge A/F ratio need to be precise or a wider range than an ICE? Carbureted or fuel injected into the air stream? ECU control with O2 sensor feedback loop?
What RPM does the turbine need to spin before fuel is introduced and ignited? What is the RPM range?
Fuel volume per KWh of electricity generated would be nice to know, too....to get a handle on fuel costs vice ICE generation for range extender operation.
So much potential, so few questions answered!
NeilBlanchard (03-23-2011)
Wonderboy's Metro XFi Revival Wonderboy EcoModding Central 44 01-29-2010 09:29 PM
Yaris and Fit to Become Dueling Hybrids SVOboy EcoModder Blog Discussion 26 08-19-2009 01:38 PM
Are Mild Hybrids Wasted Investment? SVOboy EcoModder Blog Discussion 4 04-29-2009 06:18 PM
Honda Sees Hybrids in the Future SVOboy EcoModder Blog Discussion 0 04-24-2009 12:50 PM
GM thinks 1/3rd of its cars sold in 7 years will be hybrids SVOboy General Efficiency Discussion 10 03-20-2008 04:27 PM
