03-23-2011, 11:32 PM
#41 (permalink)
...beats walking...
Iowa, the "new" Corn-Husker state?
03-28-2011, 11:35 AM
#42 (permalink)
ooo ooo ooo ah ah ah
This may be what you're after:
MIT's pint-sized car engine promises high efficiency, low cost
MIT researchers are developing a half-sized gasoline engine that performs like its full-sized cousin but offers fuel efficiency approaching that of today's hybrid engine system--at a far lower cost. The key? Carefully controlled injection of ethanol, an increasingly common biofuel, directly into the engine's cylinders when there's a hill to be climbed or a car to be passed.
These small engines could be on the market within five years, and consumers should find them appealing: By spending about an extra $1,000 and adding a couple of gallons of ethanol every few months, they will have an engine that can go as much as 30 percent farther on a gallon of fuel than an ordinary engine. Moreover, the little engine provides high performance without the use of high-octane gasoline.
Given the short fuel-savings payback time--three to four years at present U.S. gasoline prices--the researchers believe that their "ethanol-boosted" turbo engine has real potential for widespread adoption. The impact on U.S. oil consumption could be substantial. For example, if all of today's cars had the new engine, current U.S. gasoline consumption of 140 billion gallons per year would drop by more than 30 billion gallons.
"There's a tremendous need to find low-cost, practical ways to make engines more efficient and clean and to find cost-effective ways to use more biofuels in place of oil," said Daniel R. Cohn, senior research scientist in the Laboratory for Energy and the Environment and the Plasma Science and Fusion Center (PSFC).
Cohn, John B. Heywood, the Sun Jae Professor of Mechanical Engineering and director of the Sloan Automotive Laboratory, and Leslie Bromberg, a principal researcher at the PSFC, have an engine concept that promises to achieve those goals.
For decades, efforts to improve the efficiency of the conventional spark-ignition (SI) gasoline engine have been stymied by a barrier known as the "knock limit": Changes that would have made the engine far more efficient would have caused knock--spontaneous combustion that makes a metallic clanging noise and can damage the engine. Now, using sophisticated computer simulations, the MIT team has found a way to use ethanol to suppress spontaneous combustion and essentially remove the knock limit.
When the engine is working hard and knock is likely, a small amount of ethanol is directly injected into the hot combustion chamber, where it quickly vaporizes, cooling the fuel and air and making spontaneous combustion much less likely. According to a simulation developed by Bromberg, with ethanol injection the engine won't knock even when the pressure inside the cylinder is three times higher than that in a conventional SI engine. Engine tests by collaborators at Ford Motor Company produced results consistent with the model's predictions.
With knock essentially eliminated, the researchers could incorporate into their engine two operating techniques that help make today's diesel engines so efficient, but without causing the high emissions levels of diesels. First, the engine is highly turbocharged. In other words, the incoming air is compressed so that more air and fuel can fit inside the cylinder. The result: An engine of a given size can produce more power.
Second, the engine can be designed with a higher compression ratio (the ratio of the volume of the combustion chamber after compression to the volume before). The burning gases expand more in each cycle, getting more energy out of a given amount of fuel.
The combined changes could increase the power of a given-sized engine by more than a factor of two. But rather than seeking higher vehicle performance--the trend in recent decades--the researchers shrank their engine to half the size. Using well-established computer models, they determined that their small, turbocharged, high-compression-ratio engine will provide the same peak power as the full-scale SI version but will be 20 to 30 percent more fuel efficient.
But designing an efficient engine isn't enough. "To actually affect oil consumption, we need to have people want to buy our engine," said Cohn, "so our work also emphasizes keeping down the added cost and minimizing any inconvenience to the driver."
The ethanol-boosted engine could provide efficiency gains comparable to those of today's hybrid engine system for less extra investment--about $1,000 as opposed to $3,000 to $5,000. The engine should use less than five gallons of ethanol for every 100 gallons of gasoline, so drivers would need to fill their ethanol tank only every one to three months. And the ethanol could be E85, the ethanol/gasoline mixture now being pushed by federal legislation.
Through their startup company, Ethanol Boosting Systems LLC, the researchers are working with their Ford collaborators on testing and developing this new concept. If all goes as expected, within five years vehicles with the new engine could be on the road, using an alternative fuel to replace a bit of gasoline and make more efficient use of the rest.
03-29-2011, 09:30 AM
#43 (permalink)
Seems like the OP idea.
05-11-2011, 05:28 PM
#44 (permalink)
Originally Posted by Cranky
You hit the nail on the head....and we're paying for it all the way to the grocery store too with high grain prices. Food for fuel just doesn't make sense to me....
You're from Houston eh? Big oil town. Cool.
Hey why don't you mention the countless other things that use corn? Why don't you back up your claims with some documentation?
A World Bank policy research working paper released in July 2008 concluded that "...large increases in biofuels production in the United States and Europe are the main reason behind the steep rise in global food prices", and also stated that "Brazil's sugar-based ethanol did not push food prices appreciably higher". However, a 2010 study also by the World Bank concluded that their previous study may have overestimated the contribution of biofuel production, as " the effect of biofuels on food prices has not been as large as originally thought, but that the use of commodities by financial investors (the so-called ”financialisation of commodities”) may have been partly responsible for the 2007/08 spike." A 2008 independent study by OECD also found that the impact of biofuels on food prices are much smaller.
How's your oil well pumpin'?
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
05-11-2011, 06:37 PM
#45 (permalink)
^^^ I am opposed to corn ethanol for other reasons, but the food for fuel thing is really annoying. Mark Twain was dead on when he said "a lie will fly around the whole world while the truth is getting its boots on".
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
05-11-2011, 09:48 PM
#46 (permalink)
Ethanol Fan
Geesh Shovel. This topic wasn't even about that, it was about ethanol injection as in water injection.
But as an aside:
UFO, I agree. I really believe the food vs fuel was just a red herring at best. Why is it criminal to use a crop to grow a product like Ethanol when we have excessive supply and slack fields? It just defies logical reasoning  .
~Allch Chcar
