Old 02-22-2011, 11:43 AM   #1 (permalink)
Novice but learning!
Weight saving ideas
Ok, can anyone suggest any weight saving ideas that we might not of thought of? Maybe you will think different to how we do?
Thanks!
Old 02-22-2011, 12:54 PM   #2 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
- What is that shiny plate meant for in your exhaust manifold? I would also make the is it headers so that they dont penetrude so much out of the frontal area. Also if you make it closer to rear wheels you will get more grip.
- Do the series dictate that the rear wing has to be so high? If not lower the "brakects". Also I would close the gaps between those brakets on the spoiler if it is allowed.
- Can you adjust that front spoiler? It looks like its made from aluminium?, because there is so much rivets...
- Looks like your front brakes are regular steel brakes?
- Looks like you havent milled bolt heads shorter?
- What are those black hoses which go to your cam covers? Anyway you could mill some material off from that big blue anodized aluminium "bolt" Its over 80mm long?
- In my opinion your braided steel hoses could be shortened at least 10% by the look of you pictures.
Those are my suggestions.
www.tuneko.com
Less drag = Less fuel
Old 02-22-2011, 03:31 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If you are serious about weight reduction, you could get another driver that has a smaller frame.
( I'm imagining something like a 98 lb 4'11" woman that likes to race :-) )
I'm sure you have considered that already though. Just thinking out loud.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 02-22-2011, 04:17 PM   #4 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
On one of my bicycles I took off everything that didn't make it go. Off came the smaller chainwheel, front derailleur, kickstand, rack, reflectors... everything except decals and handlebar tape. Look at the bits and think "do they make this thing go?"
Old 02-22-2011, 04:46 PM   #5 (permalink)
Braided steel hose is way heavy and I see tons of the stuff, lots way high on the chassis- consider hardlines for the majority of the length and smaller flexible connectors if nessicary. Things like dry sump lines or fuel lines that run between two components mounted on the block do not require any flex. Also give consideration to routing & mounting to save length. This exercise took about 10 lbs off our road racer.
Old 02-23-2011, 05:28 AM   #6 (permalink)
-Plate on headers is purely cosmetic, so we could lose it although its made from very thin ali so is very very light.
-No rules on height of the wing no, but were looking to move it further back.
-We are changing the front end to have a wing right across the front.
-Yeah front brakes are steel, we plan to skim and drill
-the blue bolt and housing are going they weight 2lbs each! were remaking very light weight versions.
-Good point, hoses can be shortened
Thanks!
Old 02-23-2011, 05:29 AM   #7 (permalink)
Haha good point!
Old 02-23-2011, 05:29 AM   #8 (permalink)
Have to admit since this photo we did that and lost 50lbs of weight. Well worth it
Old 02-23-2011, 03:34 PM   #9 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Are the headers angled upwards on purpose, like to produce downforce ?
If not, point them straight aft.
On WW2 fighter planes, using the exhaust cleverly gained them additional speed.
The exhaust is essentially a jet, generating thrust.
Lifetime fuel consumption :
Old 02-24-2011, 04:07 AM   #10 (permalink)
Yeah to produce downforce but they are slanted back too,
