Old 06-27-2010, 10:34 PM   #31 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Impreza Outback Sport
90 day: 27.81 mpg (US)
Originally Posted by brucey View Post
With the auto in the subie, I've found that accelerating quickly (at least to 30 mph or so) is no more harmful than accelerating slowly. It gets you into the wonderful top gear much quicker that at least according to the scan gauge, it makes no real difference.
interesting, I'll have to try that. I don't have a scan gauge, so I'll take your word for it. You do get better mileage than me.
Old 06-27-2010, 10:39 PM   #32 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
I'd also only recommend it if you know it's clear up ahead, of course.
For city driving (where I can only do 24 or so during daytime traffic.. at night I can get 30 assuming I can catch the lights right) my usual method is:
From a stop, make sure it's clear, accelerate somewhat briskly (The trans will shift about 3000~3500 rpm) to about 32 mph and let the transmission shift into 4th and lock the torque converter. Try to hold that as gently as possible if it's a long stretch... OR Put it in neutral if I know I can coast to the next stop, if there is traffic I'll try not to get too low under the limit for courtesy sake.
If you give it too much gas (nearly floored) it will change the fuel trim and go into a more rich burn for about a minute before going back to its normal mixture.
We've both got the 4EAT, so I assume yours is very similar. The gearing (Mine is 4.444) is probably the only difference. So just try and find out how low you can get the torque converter to lock up in 4th. (The rpms will stop varying with throttle and the car will buck a bit more while accelerating, like in a manual car)
RobertSmalls: Yeah, I know what you mean. At my normal cruising speed (55~60) I'm around 2500 rpm, so between that and the 4.444 final drive I think I have plenty of power to make up a few extra pounds.
Daily Driver
Winter Beast
Old 06-30-2010, 03:02 PM   #33 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
Originally Posted by RobertSmalls View Post
Lucky you; that looks like the better torque curve.
It's always frustrating to see how high most dyno plots start. I used to upshift my Subaru at 2000RPM, so this plot captures none of what I care about.
Well, when you look at the average intent when dynoing a car, you can see why such low RPM is never looked at. But one reason simply is setup, trying to not "bog" the motor from such a low RPM to read a very small amount of power.
However, there are other ways to measure HP off a dyno.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 06-30-2010, 05:25 PM   #34 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
Originally Posted by Old Tele man View Post
...here's an equation for vehicles in the 3,000-lb. range, attributed to Detroit, that's used to estimate weight changes upon fuel economy:
(MPG2 / MPG1) = (WT1 / WT2)^(0.72)
...where: suffix-"1" is old and suffix-"2" is new.
MPG2 = MPG1*(WT1/WT2)^(0.72)
MPG2 = 26*(3000/4000)^(0.72) = 21
Not even close to what I observed. If I had dropped below 24mpg I would have to get gas at both ends of the trip. Only once did I have to get gas midway in the trip, and that was when I had beds hanging out the sides and over the top.
Old 06-30-2010, 05:48 PM   #35 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
If this applies to weight of the car at the design level, it includes an upsized engine as well. So 3000lb becomes 4000lb, 26mpg becomes 21mpg, your 2.2L becomes a 3.0L, and the car is no peppier.
The Following User Says Thank You to RobertSmalls For This Useful Post:
TheEnemy (06-30-2010)
Old 06-30-2010, 06:03 PM   #36 (permalink)
TheEnemy's Avatar
Ok that makes better sense, in fact it fits pretty well with if I had gotten the 4X4 version with the V6.
It wouldn't relate well to whats being discussed here though because we are compairing loaded/unloaded weight.
Old 07-02-2010, 09:53 PM   #37 (permalink)
Ecomodder
Fr3AkAzOiD's Avatar
Cobalt XFE - '08 Cobalt XFE
Team Chevy
90 day: 54.89 mpg (US)
'08 XFE average for 2012 - '08 Cobalt XFE
'05 Malibu V6 Tow Vehicle - '05 Malibu LS V6
90 day: 30.07 mpg (US)
This topic came up in another forum (sorry, no link) and one of the things that was brought up is how much torque the vehicle produces.
Vehicles that produce more torque seem to be effected less by a weight increase then one with less torque.
Lifetime mpg
2012 mpg
Old 07-04-2010, 12:38 AM   #38 (permalink)
I just got my best tank ever, and I had the car loaded with about 500lbs of stuff on the return trip (tank was for both ways). Granted, everything when really well as far as driving conditions. But I also had the CEL on the whole trip (O2 and knock).
I have found it almost pointless to P&G at 60 with my car. It has to be one heck of a hill, and then to get it back into gear, and get the torque converter to lock seems like it balances out most of the benefit. But with a heavy load it drives like a aerodynamic Legacy!
Old 07-04-2010, 12:44 AM   #39 (permalink)
I have found it nearly impossible to get it to lock under 41, but when it does I can holed it down to 30.
Old 07-16-2010, 06:53 PM   #40 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
That's the hysteresis for the TCC logic. There is often a minimum vehicle speed, RPM, coolant temp, max engine load, max TPS %, and a couple of qualifications timers for the lock function.
To unlock, basically the reverse is true with some additional factors such as delta-TPS, brake-pedal switch, park-neutral switch, delta-MAP, and of course the MPH hysteresis which gives the delay so you don't have constant locking and unlocking.
You can get better mileage by adjusting most of these calibrations.
Big project-F250 pulling 20x8.5 enclosed trailer 5.0 Junkie Aerodynamics 70 04-11-2010 01:10 PM
Import Tuner Magazine: mods an Integra for speed, handling and efficiency MetroMPG EcoModding Central 15 03-18-2010 02:14 AM
Geo Metro 13 inch steel wheel weight MetroMPG EcoModding Central 8 06-25-2009 11:10 PM
Tire size vs. hub width and weight limits Piwoslaw EcoModding Central 3 06-25-2009 06:50 AM
weight loss achang1 EcoModding Central 7 09-30-2008 05:17 PM
