Old 08-08-2009, 09:45 PM   #1 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Were my tires throwing off my fuel logs? Help
Hey I was looking at a profile on here where someone said that the tires on their car or whatever it was were 6% bigger then the stock so he calculated the 6% into the fuel logs for 6% addition to the miles driven. The tires I had on for a while are 10% bigger then the stock/ones I have on now. Was I suppose to add in that 10%
Old 08-08-2009, 09:57 PM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Yes. :P You screwed up.
What you actually have to do is calculate the difference in rolling circumference, not diameter. You add in the % difference of the circumference, since you've gone that much further.
Old 08-08-2009, 10:01 PM   #3 (permalink)
The Neon - '00 Neon
House of Tudor
So can you tell me what I need to do to my fuel logs for when I had those tires on? add or subtract from them and by how much?
Old 08-08-2009, 10:02 PM   #4 (permalink)
Steve - '92 Festiva
If your tires were 10% bigger circ, you add 10% to the miles driven.
Old 08-08-2009, 10:16 PM   #5 (permalink)
The Neon - '00 Neon
House of Tudor
So that chart is correct? I DO use 10% in this situation?
If so then for ex. if I drove 300 miles I should take 10% from 300 and add it to the 300, that being 330 and put 330 in the place of the 300 right?
Old 08-08-2009, 10:21 PM   #6 (permalink)
Steve - '92 Festiva
Old 08-08-2009, 10:23 PM   #7 (permalink)
The Neon - '00 Neon
House of Tudor
are you 100% sure before I go and modify 9 of my fuel logs 4ever?
Old 08-08-2009, 10:26 PM   #8 (permalink)
Steve - '92 Festiva
Do I have to support my statements with logic?
Old 08-08-2009, 10:28 PM   #9 (permalink)
The Neon - '00 Neon
House of Tudor
No, besides I cant argue with writing down a less-good FE than it was
Old 08-08-2009, 10:30 PM   #10 (permalink)
Steve - '92 Festiva
It'll show better mileage... more distance on the same fuel.
fuel log, problem, tire size
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
