Old 01-10-2012, 12:36 PM   #1 (permalink)
What about a Lotus Elise-like hot air outlets in the hood?
Will they improve aerodynamics?
They have some cutouts in the hood to allow hot air from the radiators to exit.
Lotus Elise - Wikipedia, the free encyclopedia
Old 01-10-2012, 03:50 PM   #2 (permalink)
OurInsight - '06 Insight
This is the approach to that Hucho says is lowest in Cd. Hucho points out that the approach is not appropriate for street cars because it dumps the engine compartment air at the same point as the cabin fresh air intake. I saw an Elise recently but didn't note how Lotus solved that problem. Their cabin vents must be somewhere else.
The Following User Says Thank You to jimepting For This Useful Post:
NeilBlanchard (01-11-2012)
Old 01-10-2012, 04:57 PM   #3 (permalink)
euromodder's Avatar
Hδgar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
It's like a configuration seen in Hucho's book on car aerodynamics, and also tried out by forum-member Vekke on his Seat.
Lifetime fuel consumption :
Old 01-10-2012, 06:41 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...similarly, it's like the dual hood vents on the Ford GT40's etc.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 01-10-2012, 08:15 PM   #5 (permalink)
if you do it this way, you have to be very careful to keep the outlets far enough in front of the windshield, and also to keep the windshield at a very steep angle.
For most cars, air stacks up in front of the windshield creating a high pressure, stagnant area, which is why the fresh air intakes are located in this place for most cars.
If you look at all the examples, they try to keep the radiator outlets far to the front of the hood, and the windshields are all steep.
Old 01-10-2012, 08:37 PM   #6 (permalink)
Shepherd777's Avatar
Ford originally had just one large opening hood vent on the GT40.
But they found out that adding a vertical splitter in the center, it sped up the exiting hot air considerably. Which in turn, made it more efficient and effective.
Another more contemporary example, and my personal favorite, is one I brought up in a different post. The new ZL1 Camaro.
Old 01-10-2012, 09:30 PM   #7 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
My car also has those hood vents... The windshield is pretty steep, though.
Old 01-10-2012, 09:39 PM   #8 (permalink)
That may just mean that they designed them for looks, and not function.
Old 01-11-2012, 12:03 AM   #9 (permalink)
Where is this build thread to be found. I searched using several different methods and could not find it. Thanks.
Old 01-11-2012, 12:06 AM   #10 (permalink)
Team Emperor
No, it's definitely for function, but the purpose might not primarily be aerodynamics. I know it vents heat a way for sure, but it might also lower the CD.
