Old 03-06-2009, 01:14 AM   #11 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
More or less the stock filter element with custom, temperature dependent, air sourcing is my choice. I tried K&N, but it yielded no advantage -- in fact the maintenance quite costly and the darn thing disintegrated (I know, there's a warranty, but I don't want another).
I have a straight pipe entering the airbox to draw warm air from the exhaust manifold. The disadvantage is a growl under high throttle input. Otherwise, the filtration rate is moot so the OEM paper replacement is just fine.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 03-28-2009, 09:23 AM   #12 (permalink)
Weight Reduction
Drive Stick's Avatar
neon - '95 neon Highline
90 day: 37.7 mpg (US)
Subaru - '98 Legacy L Wagon
90 day: 29.94 mpg (US)
Saab - '98 900 S
90 day: 51.25 mpg (US)
Impreza 2.5i - '011 Impreza 2.5i
90 day: 24.06 mpg (US)
Blue Crush - '011 Prius II
90 day: 50.98 mpg (US)
Send a message via AIM to Drive Stick
I use purolator pureone air & oil filters. Gold box only, outperformed all the rest in my opinion / personal testing.
To each their own, but any amount of research always leads me back to this brand.
Old 03-29-2009, 09:38 PM   #13 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I've used the same stainless steel mesh filter by APC (Ya, I know) for over 5 years now. When it gets dirty enough that it doesn't look shiny any more, I just rinse it out from the inside, don't bother drying it, and reinstall it on the car. It cost me $20 on sale, down from $30 something.
I've used it on multiple vehicles, although it's a cone filter. I don't worry too much about noise under the hood, so the "growling" of the engine means nothing to me, and I remove the OEM airbox. There is usually no weight savings in doing this.
I've never experimented with warm air intakes, I've always pointed my filters to colder air locations, but I can't speak to FE gains or losses, since I never really recorded anything, and my "datafield" would be far from invariable.
I can say that switching from that filter to an open-cell foam *non-oiled* cone-type element on the same smooth intake pipe with no PCV, I got worse mileage SUBSTANTIALLY (like 3-5MPG worse.) and 0-60 took about 1 second longer. (1989 Civic DX, CAI, cat-back 60mm exhaust, open muffler, 3 angle valve grind and intake porting/polish, drilled fuel rail.)
Old 03-30-2009, 03:11 AM   #14 (permalink)
RH77's Avatar
Whatever's at the auto parts store, paper, and cheap.
My model requires a full canister unit that could technically operate without an airbox.
My K&N filter disintegrated after about 3-years operation, and routine maintenance.
Bottom Line: Spend money elsewhere and get an "OK" filter. Filter flow rates are hogwash -- there are many other locations in the air stream that greatly effect engine operation: specifically FE.
Christ -- Your 0-60 results: were they under the same environmental conditions? Otherwise, I call "butt dyno".
RH77
EF5 / 22-May-2011
_
_
Old 03-30-2009, 04:38 AM   #15 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
^Yup
Old 03-30-2009, 07:19 AM   #16 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Nothing but OEM.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 03-30-2009, 06:06 PM   #17 (permalink)
Steve - '92 Festiva
0-60 runs were on a flat level runway on a 50 degree day, engine pre-warmed. I ran the tests back to back, three runs with each engine left to idle between to maintain constant running temps, so it was AAA BBB AAA BBB at full throttle each time, launching off a 2-step rev-limiter at 2400 RPM with basically a clutch dump (unsprung clutches don't like to ride out.) Wheel spin was limited.
The only reason I tested it was b/c I couldn't believe that the foam filter could restrict THAT much airflow, but I felt a major difference when I put it on, so I had to check it out.
Old 12-15-2009, 08:53 PM   #18 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
I prefer K&N and it's always showeed gains for me but my buddy put an amsoil air filter and swears by it in his jeep,, Actually i've talked to quite a few people who like the Amsoil I'd suggest lookin into that
Old 12-15-2009, 09:03 PM   #19 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Thanks for the tidbit of info.
EDITED
Old 12-15-2009, 09:03 PM   #20 (permalink)
Steve - '92 Festiva
Hey, this one's an opinion thread. I guess it's OK in here.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Air filter saunders1313 Hypermiling / EcoDriver's Ed 33 07-03-2010 11:35 AM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Broken Air Filter Discovered RH77 Off-Topic Tech 2 07-03-2008 10:14 PM
