Old 10-21-2008, 11:09 AM   #21 (permalink)
extramiler
12voltsolar's Avatar
A4 - '01 A4 Avant sport
90 day: 32.42 mpg (US)
Originally Posted by TestDrive View Post
MAF needs "cleaned" much more often than it needs "replaced."
Changing MAF implies a reset of the ECU. Typically an ECU will take a few miles (eg 150 mile) to fully recalibrate itself. If you're FE drop is based on a scan-guage or similar reading, give the ECU a little time to tune itself in.
If you've already gone 150 miles or more and the FE is still down more than colder weather would account for, you might want to double check that the mechanic didn't introduce a spec of lint or crude on the new MAF when he installed it.
Hey TestDrive, not sure that it needed to be cleaned only, may have been, but as I say it already was replaced (past tense)...
I'm fortunate in the A4 to not have to run a scan-guage or similar product the car has a nice built in system that tracks and displays Ave MPG, Ave Speed,
realtime MPG, engine run time in hours & mins., and approx miles left until the fuel runs out (which makes for a fun ecodriving game to squeeze out more miles then the factory computer thinks you will get)
Thanks to the EM Garage I can tell you that I've driven 1,899.9 miles since the service (Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com) my lowest FE per fill up was on 9-27-08 first full tank after the service. I think the engine control unit (ECU) has had plenty of time to adjust...
I'm thinking secondary air injection system has an issue, this is very common on VWs and Audi's. the pump's plastic housing is just riveted together and they rust and break... also the combination valve has issues in these cars.
it really is a great car...
Old 10-21-2008, 03:43 PM   #22 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by Compaq888 View Post
A couple mpg. I got 31.4mpg driving 200 miles at night on the freeway with a warm air intake. When I put the stock intake and filter on I would get 38-39mpg. Huge difference if you ask me. This is why i'm keeping everything stock on this car.
Definitely sounds like your WAI modification plumbed into the system after the MAF instead of before the MAF.
IF no air flows through the MAF the ECU is forced to operate in open loop. Hence your 17% decrease in fuel economy.
Old 10-21-2008, 11:33 PM   #23 (permalink)
Metrosexual - '91 Metro LSI
90 day: 50.36 mpg (US)
Gaszilla - '88 K1500 Sierra
Originally Posted by cfg83 View Post
Metrosexual -
Isn't this the logic behind the CAI (cold air intake)? The goal is to get cool "humid" air into the engine in order to increase the oxygen and thereby increase the amount of fuel injected.
Question: How come some people report better mileage on cold wet days? This sounds like a contradiction to me.
CarloSW2
Yes this is what a cold air intake does, and I have found that I get significantly worse gas milage in cold wet weather. Cold being 30-40degs f.
I am thinking of installing a block heater to alliviate some of this
Old 10-22-2008, 11:27 AM   #24 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I get better mileage in humid weather.
I get lower mileage in cold weather.
I get lower mileage in wet (rain) weather.
The best combination is warm and humid. Like Florida.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 10-22-2008, 09:23 PM   #25 (permalink)
My car behaves exactly the same way.
I used to get 50mpg on the freeway but now it dropped down to 45-47mpg
time to do another maintenance.
Old 10-23-2008, 12:40 PM   #26 (permalink)
AeroGuy
eco_generator's Avatar
4x4 Wagon - '89 GL Wagon 4wd
Subaru
90 day: 31.58 mpg (US)
Fromeo - '07 Fit Base
90 day: 46.09 mpg (US)
A new MAF sensor might just give the engine the correct airflow so it can fuel properly. Running lean with a bad signal will increase your gas mileage, but your piston tops might complain if that happens under load...
Old 10-23-2008, 04:29 PM   #27 (permalink)
How long since it was replaced?
Every time the air filter is inspected is an opportunity to introduce a spec of lint/dirt. It only takes a tiny spec of gunk on the small heated wire that is the guts of the MAF to cause inaccurate air flow reading for the ECU.
Also if you've installed a K&N or other "high performace" filter that requires periodic cleaning & oiling, even a slight over oiling will lead put a film on the guts of the MAF and cause inaccurate readings sent to the ECU.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 04:11 PM
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 5 08-11-2008 02:35 AM
