Old 02-18-2008, 12:57 AM   #11 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
My intake temps fluctuate pretty quickly... If I'm moving with a mostly closed throttle, IAT goes up. If I open the throttle and allow the rpms to climb, IAT goes down. If I'm coming from a stopped idle up to speed, my intake temp can drop 15+ degrees while accelerating and then climb back up a little bit when I steady off my speed.
I'm fairly confident it's just a function of mass flow, heat soak and the intake source. At least in my case
I also don't notice any sound increase without it. I'll report any significant FE changes as well.
Unless you've got flappers in there to change the intake length -- that resonator is optimized for one specific frequency. Likely the loudest one... You probably won't notice it until the right conditions - or you'll pass it so quickly it won't be very noticeable...
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 396 06-13-2022 01:51 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
Cooling system drag Daox Aerodynamics 7 01-29-2008 09:01 PM
Cost of block heater install popimp EcoModding Central 5 12-29-2007 08:38 PM
