Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 12-04-2007, 10:49 PM   #1 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
What does YOUR bike weigh?
So it occurred to me about 3 minutes ago that I've never weighed my bike, and therefore I have no clue what it weighs. Being ever the slave to my curiosity, I proceeded to grab my bathroom scale, head out into the garage and get my weigh-in on.
So my previous Wild A$$ Guess as to my bikes weight was somewhere between 25-30 lbs.
So I was nearly giddy when I saw good old Margot weigh in at a svelte 43 lbs.
I gotta quit pampering my bike so much, at 43 lbs. I can pretty much run it over with a Mack truck and not do any damage.
So how much does your ride tip the scales at?
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 12-04-2007, 10:59 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
If I'm not mistaken (and I may be... a little foggy on this one), I think my old Pirate Bike is exactly the same weight!
Old 12-04-2007, 11:08 PM   #3 (permalink)
AndrewJ's Avatar
Mystical bicycle convergence?
You be the judge!
Old 12-04-2007, 11:19 PM   #4 (permalink)
Now I have to go weigh it again. (OK, tomorrow I'll weigh it again.)
I already heap abuse on mine: earlier this fall, it slid down a rocky shoreline (steeply sloping shoreline, thus the problem) and fell about 5 feet into the St Lawrence river. I was sitting on a rock about 10 feet away at the time. I laughed. So did a few other people in the park who saw/heard the descent & watched the retrieval process.
Fortunately I was not on it at the time. Also fortunately there was a way down (and up) to the water, and the water wasn't deep.
The latest abuse: I left it out in the open for the first big snow/ice storm, and next time I rode it, the only lever or handle that wasn't frozen solid was the front brake! (Not my preferred choice on snowy roads.)
Old 12-04-2007, 11:21 PM   #5 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Going up hill won't be much fun but the ride down should be pretty quick.
"Judge a person by their questions rather than their answers."
Old 12-04-2007, 11:32 PM   #6 (permalink)
AndrewJ's Avatar
with a 26 tooth chainring on the front and a 34 tooth cog on the back(114.2-20.9 gear inches), uphill is a lot more fun than with my old lightweight singlespeed (75.6 gear inches).
*Gear inches is the distance that your bike moves with every complete revolution of the cranks*
Old 12-05-2007, 12:38 AM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
My bikes is pretty much a porker at 58cm and 23 pounds! I want it to be sub20 eventually, which I think is decent for a 58cm bike. Oh wellz.
Old 12-05-2007, 01:37 PM   #8 (permalink)
OK, it's not quite in the same league as your 43 lb porker.
37.5 lbs.
Old 12-05-2007, 02:54 PM   #9 (permalink)
ECO-Evolution
Lazarus's Avatar
C-3 - '08 XF50X
You would probably be better off buying a sub 20# bike then to try and get the weight off that one. It really gets expensive when you try and put your bike on a weight reduction program. If you look hard you might find one for around $500-700.
Mine comes in just under 21. Woot
Old 12-05-2007, 04:02 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
The problem for me is I don't know where the weight it right now. I'm going to get a new set of wheels at some point, which should kick 2 pounds off, but other than that I'm guessing it's just in the frame. I really don't care that much about the weight though, and I like the look of my frame more than the newer carbon frames anyway. *shrug*
