Old 08-12-2008, 11:29 AM   #1 (permalink)
chilimac02's Avatar
What % gain does a Warm Air Intake yield?
Does anyone have some A-B-A tests to show? I keep hearing it helps, but how much does it help? How do I do it? Will my 2001 Accord run properly with it, or will I have to buy higher octane gasoline?
As you can see, I'm confused...
Old 08-12-2008, 11:29 AM   #2 (permalink)
chilimac02's Avatar
I have a scangauge II so I can check results, etc.
Old 08-12-2008, 01:05 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Well, this is one of those things no one can really say. It depends highly on the car, the temperatures, and other junk. The best way to tell would be to test it for yourself with a SG
Old 08-12-2008, 02:14 PM   #4 (permalink)
The Vue - '03 Vue
90 day: 25.34 mpg (US)
it helps some cars and hurts others, I like to think it helps my corolla, but i havent done any actual testing (besides the throttle response sounds cool when/if i ever have to step on it. )
Old 08-12-2008, 03:03 PM   #5 (permalink)
Roman's Avatar
Golf D - '83 Golf GL
90 day: 42.79 mpg (US)
You don't have to use higher octane. It's just you have less O2 in the air so you need less fuel to run. You will have a little less power and need less fuel. On my Suzuki Swift it makes i think about 4-5%.
It's like the same with a Turbo. A turbo compresses air, so you got more air and need more fuel. And as a side effect you have also more power . I know someone with a Swift with a turbo went from 40 MPG to 25MPG.
You may need higher octane when you change ignition timing.
NOW INTERACTIVE! Joystick controls Fry's left ear.
Old 08-12-2008, 06:12 PM   #6 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
I can say with some certainty that a WAI neither helped nor harmed my FE. Interestingly, it did quiet it down some, vs. the CAI.
Old 08-12-2008, 06:39 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
SVOboy -
I would be leery of using the SG to quantify the actual % gain. From what we (think we) know, the SG is using an algorithm to determine MPG, and the IAT is a significant parameter in that algorithm (see here). The ECU/PCM, however, is using the 02 sensor's Air/Fuel ratio to determine how much fuel to inject.
CarloSW2
American Solar Energy Society
Old 08-12-2008, 10:12 PM   #8 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Modifications that reduce the maximum horsepower do not necessarily reflect on the fuel usage at other throttle settings. The main potential benefit of WAI is to aid fuel vaporization, and to quickly turn off the rich "starting" mixture setting.
Old 08-12-2008, 11:29 PM   #9 (permalink)
chilimac02's Avatar
Thanks Bob!
If you're right, and I assume that you are, then I'm not going to mess with doing a WAI. My car is garaged, and goes into closed loop almost immediately.
Old 08-12-2008, 11:32 PM   #10 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
Another thing I have read is that the warmer air is thinner. This in theory allows you to open throttle more reducing pumping loss.
accord, warm air intake
Warm air intake? how about warm fuel? ebacherville EcoModding Central 30 03-08-2010 09:37 PM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
carbed car .. think a warm air intake will help? ebacherville EcoModding Central 21 06-29-2008 09:16 AM
Warm Air Intake whokilledthejams EcoModding Central 2 06-18-2008 06:28 PM
