Old 06-04-2008, 09:09 AM   #1 (permalink)
Here, there, everywhere
regor's Avatar
regor's civic - '08 civic lx
90 day: 39.95 mpg (US)
What gauges do you use on your scangauge?
Just curious.
I have mine set for:
MPG-So I'll know my exact MPG at that very second
CPM-Like to know what the fuels is costing me for every mile
FWT-Like to know what my water temp is
VLT-I like to know the voltage.
For the trip reading, I like to view what my overall MPG for the day is.
I drive-
08 Honda Civic LX sedan, auto
01 Chevy Silverado truck
99 Ford Contour sedan (Well, that's the wife's).
And a 1907 Baldwin Steam Locomotive (Really)
I tend to convert to Mobil-1 around the 8K mark
I'm also a believer in "Tufoil"-been adding that in my vehicles for 20+ years (And yes, I'm experimented with Duralube, Slick50, Prolong and zmax, and what did I find? No improvement in MPG. I keep on coming back to Tufoil).
Old 06-04-2008, 09:25 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I play around with mine a lot depending on what I want to watch. But, I usually always at least have instant MPG, average MPG, and engine load. Other than that I watch GPH, coolant temp, and intake air temp.
Old 06-04-2008, 01:10 PM   #3 (permalink)
EcoModding Newbie
Parachute - '03 Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Neon Highline baby!
90 day: 31.39 mpg (US)
Instant MPG, throttle position(my pedal is touchy), RPM(no tach in my car), and lately IAT or IGN, I have to program the trip mileage in an Xgauge, I've been putting it off.
Ian
p.s. Does anyone ever see negative IGN numbers, my parents have a 07 CRV with terrible mileage. We plugged in the scangauge and on start up there was negative IGN advance. No engine codes either.
Old 06-04-2008, 01:51 PM   #4 (permalink)
TPS, RPM (no tach for me either), Instantaneous MPG, and average trip MPG.
Old 06-04-2008, 03:17 PM   #5 (permalink)
adam728's Avatar
97 LeSabre - '97 LeSabre Limited
90 day: 26.95 mpg (US)
Throttle position
Air intake temp or ignition timing
Coolant temp
Instant MPG
IndyIan - I see negative numbers in my gf's turbo Passat when decelerating. My assumption is that it retards the timing way back to keep exhaust gasses as hot as possible so the turbo spools faster when you step on the gas again. I don't know for sure though.
Miles displaced by bike in 2008 - approx 68
Miles added to vehicle by driving to rides with buddies - way more than above
Old 06-04-2008, 04:21 PM   #6 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
Instant MPG
Trip MPG
GPH (gallons / hour)
VLT / FWT back and forth.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 06-04-2008, 04:44 PM   #7 (permalink)
You know, it'd be really cool if you could set even just one gauge to cycle through a select amount of gauges. Something like have the upper right gauge flash through x/y/z every 2/5/10 seconds.
Old 06-04-2008, 04:49 PM   #8 (permalink)
Now that WOULD be cool! VLT, FWT, Intake temp would be my choices.
Old 06-05-2008, 12:37 AM   #9 (permalink)
30+ MPG ford ranger
FoMoCo_RANGER's Avatar
babyblufasty - '73 type 3 FASTBACK
90 day: 20.31 mpg (US)
FoMoCo - '01 ranger XL
90 day: 26.38 mpg (US)
OXFORD - '06 ranger XL
90 day: 33.33 mpg (US)
i have RPM, MPH, MPG, and CPH usually, but i do have the HPR, temps, and volts
Old 06-05-2008, 08:51 AM   #10 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I always have trip mpg and instant mpg or gph. Other than that I cycle between IGN, MAF, AFR, IAT, LOD and TPS. I will look at the SFT and LFT now and then too. I would LOVE to be able to log this stuff. It would be easier for me to see how my car manages the fueling if I could make maps from the data.
On the TDI I also use a PSI Xgauge, which is basically just the MAP less barometric pressure. I use it to monitor my turbo bleed by comparing what the ECU sees with what my mechanical gauge reads.
www.HyperKilometreur.com - Quand chaque goutte compte...
Stock Temperature Gauges jcantara Instrumentation 24 05-27-2010 12:26 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Three most useful gauges? JJW Instrumentation 35 10-24-2008 04:31 AM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
OBD-II port (how to run 2 gauges on one port) thebrad Instrumentation 14 04-09-2008 12:10 AM
