Old 09-02-2009, 11:29 AM   #1 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 CHEROKEE XJ
Last 3: 21.58 mpg (US)
What gear oil is thinner Amsoil SAE 190 or 75w 90?
Trying to get the thinnest synthetic gear oil for my 4x4.
whats thinner amsoil SAE 190 AMSOIL - Severe Gear® Synthetic Off-Road and Drag Racing Gear Lubricant SAE 190 (SRN)
or amsoil Severe Gear 75W-90 AMSOIL - SEVERE GEAR® Synthetic Extreme Pressure (EP) Lubricant 75W-140 (SVO)
or should i use something else thats even thinner??
Old 09-02-2009, 04:29 PM   #2 (permalink)
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
Acoording to the viscosities given for these oils the 75W-90 is the thinnest oil.
Old 09-03-2009, 05:59 PM   #3 (permalink)
i also found red line oil and they are 75w 80
thats the lightest gear oil out there any other ideas.
Old 09-05-2009, 07:06 PM   #4 (permalink)
Look at Redline's super light shockproof oil. It's exactly what you're looking for, as it's half the viscosity of typical gear oils. 8cSt vs. 16cSt.
Red Line Synthetic Oil - Superlight ShockProof®
Old 09-05-2009, 07:38 PM   #5 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
I just went and checked that out..seems a bit too good to be true, but the cost is decent. I also have a prblem with wanting light gear oil. a one piece dual ranged AWD tranny behind a 90hp boxer. Diff built in
* Film thickness greater than an SAE 75W90, yet low fluid friction like ATF
* Used in low-power dog-ring racing transaxles with moderate to low load, qualifying, etc.
* Popular in British F3, Euro F3 and Star Mazda racing gearboxes for ultra low drag
I do need the so called friction additive for the diff.. I changed a sube trannies fluid just once without it. It does do something important. I wonder if it can be added to redline. Sorry to rob the thread and ignore everybody but myself. gimme gimme gimme
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
Moly Gear Oil Additive Sources? Redline MTL or ??? rmay635703 EcoModding Central 3 03-07-2009 02:00 PM
