What happened to the envirofit envirokit?
Just wondering, this seemed like a novel idea and supposedly they were going ahead with conversions but...
2-Stroke Retrofit Technology - Field Testing | Envirofit - Making the World Fit for Humanity Nothing happened. Any ideas if a method of getting fuel injection on a 2 cycle exists? (aka one that doesn't involve blowing through the port into the exhaust like the carb does anyway) I notice some scooters already have a system like this, I wonder if I could locate a junker of a similar motor style to mine, drill and tap a few holes in the head and get a 2 cycle DI setup? Maybe too optimistic. Ah well Ryan |
DI would take a bit of work and a high-pressure injection system. Remember, if it's DI, you're injecting into an already high pressure atmosphere while the cylinder is up.
You could set up a single cylinder EFI system that didn't inject fuel until (x)ms before the exhaust port was covered, thereby only letting fresh air flow out the exhaust. You've still got the oil issue, though, which I suppose can be made up for with synthetic/low E oils. |
I saw a video on Youtube that they uploaded, and I think they were able to retrofit a few hundred or maybe a thousand or two bikes in Malaysia or something. No idea what happened after that.
They had a fuel pump, a replacement head with the injector, and probably some sort of replacement oiling system. Ideally you'd have a separate supercharger ish thing rather than using the crankcase to pump air too, and at the expense of a small amount of pumping loss you can greatly diminish the importance of exhaust tuning. Two strokes have a lot of potential...I think I've seen somewhere that piston ring wear due to the uncovering and covering of ports is an issue for reliability as far as adapting them to cars goes however :/ Emissions control is obviously quite a bit tougher too, although using a timed exhaust valve would help. |
They trialled this in the Philippines. Think they hit their targets and closed shop, since all new utility motorbikes here must be, by law, four-stroke.
Timing a 2 cycle is simple as it gets, the ports and exhaust should be tuned as is for the motor the spark, o2 and injection timing would be left but again would be simple. My main interest was the 30-40% increase in economy, not the oil issue. Too bad a kit like this does not exist, I could see many uses for one. Cheers Ryan |
DI kit
You can try contacting Envirofit at envirofit dot org
but I don't think they will sell you a kit because they are not approved for the US. I don't think they would have any problem getting them approved, but there would be no purpose in that as far as Envirofit is concerned. I think they have abandoned that project and now are concentrating on a new one, supplying highly efficient wood and biomass burning cookstoves for undeveloped areas of the World where indoor pollution is causing millions of deaths and illness. You might try buying one of the kits from the Philippines. A taxi, or "tricycle" owner might sell one that is no longer being used. They save a lot of gas and oil with the kits. I think all the parts are off-the-shelf, but finding them may be very difficult. Orbital Corporation in Australia provides the low-pressure technology used in the DI kits. It uses compressed air to inject fuel into the combustion chamber after the ports are closed. Most of the air in the cylinder comes through the crank case, as in a normal two-stroke, and the oil also goes into the crank case. You might try orbeng dot com dot au to try to get some information. I think you would be able to modify a head. The kits are made for Yamaha RS100 motorcycles as well as a Kawasaki 125 and a Suzuki 100, all from the seventies and eighties as far as the U.S. is concerned. I have a 1975 RS100 and would have liked to have gotten one of the kits. Instead, the bike has been converted to LPG fuel. Let me know what you find out about possibly buying one of the kits. I hope you can make out those addresses. I don't have enough posts to allow urls. |
Invennovations.com - Categories > Emissions Reduction
Very sad that the best products never go to the us? |
The car got tremendously better fuel economy as a DI 2 cycle but due to NoX it was shelved. Dodge might have been viewed here in a better light had that design been produced but lean idle and midrange were considered defects and not celebrated, Too bad really. Imagine all of the Dodge Neons on the road getting 10mpg better and weighing 100lbs less? |
