Old 03-14-2010, 09:54 AM   #11 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Originally Posted by bhazard View Post
There was no laughing that I knew of. Its not all that uncommon to take a slow car down a drag strip. Its more for fun than anything, and you can even win bracket races in a slow car.
I won 5 rounds at a drag strip with my 96 3 banger Geo running 19.9s at 65 while leaving at 3500 rpm and shifting at 5700. I was shifting into 4th right at the mph timing light (starts timing for mph at finish line) and on the [pass that I didn't shift into 4th it ran the 19.84 at 66 mph. The 1/8 miles were all in the 12.57-12.59 range at 57 mph. Two more rounds and I would have won $1000!!!!! The car was bone stock mechanically but lightened up 100 lbs.
I beat one 14 second car and the rest ran 9-11 seconds in the 1/4...my regular car (05 SRT4 Neon...now in the 12s) was sitting with a broken axle.
I use this as a daily driver and a delivery behicle for rims/tires that I sell.
You can check out photos of my cars and those I race against here:
My SRT4 Neon
Hyper-Performance Motorsports Inc. Photography
Me giving a .14 second head start to a much modified Mustang...check out his tires!
Me giving a head start to a wheelie popping Mustang
Me giving a near 2 second head start to a SHARP old school Camaro
Me closer to stock
Even the 3 cylinder Geo gets action
The White Gnat strikes again
NHRA Div 3 ET Finals pics
DSC_0681 on Flickr - Photo Sharing!
Ditto
DSC_0679 on Flickr - Photo Sharing!
Left front corner of hood
DSC_0677 on Flickr - Photo Sharing!
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
Old 03-14-2010, 10:02 AM   #12 (permalink)
As far as taking a larger motor into a lighter car...that will improve the gas mileage of the bigger motor set up in the heavier car for sure if the gear ratio/tire sizes remain the same. I have not done a motor swap on my 3 banger Geo BUT taking 100 lbs out of it saw a 1 mpg mpg improvement on the hiway. If I deliver a set of rims at 100 lbs the mpg goes back to the original. If I deliver the maximum load of 8 rims/tires then I loose 4 mpg due to the extra 400 lbs and you can really feel the performance difference...almost as if the car is not running correctly!
95 Neon / 46 mpg
Old 04-07-2010, 10:37 AM   #13 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
Sorry for the lack of updates, but...
tada
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 04-08-2010, 08:08 PM   #14 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Nice!
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 06-13-2010, 11:18 PM   #15 (permalink)
bhazard's Avatar
Ive put like 6000 miles on this thing in two months, have gotten a best of 40.1mpg out of it, and just the other day found out I've been running on 3 cylinders the whole time. The wires for one of the injector plugs were loose. Now I'm pretty sure this is why I was getting abysmal mpg with the o2 sensor plugged in, like 32 mpg. I would get 38-39 without the o2. I would imagine missing a whole cylinder worth of fuel would look quite lean to the o2 sensor and tell it to dump in as much fuel as possible.
I thought the car was quick already but holy crap this thing screams now. It will rip the tires off in 1st and half of 2nd and has no trouble maxing out the 85mph speedo. I only have a few issues now, one of which is the rear suspension is worn and is squatting under hard acceleration allowing the front end to come up and spin the tires. Another thing is Im running open exhaust now (hearing that turbo whistle coming from a FESTIVA is awesome) and theres too much flow basically, the wastegate cant bypass enough, so it creeps up to the 11psi overboost cutout, which you can see in my video. I need a chip for the ecu that allows you to go over 11psi.
Heres a video of me ricing around, don't mind the granny shifting, overboost cut, or oil light.
ON THE FLIP SIDE OF THINGS (the more mpg friendly side)
Its REALLY friendly to drive ecomodder style. This thing lugs down to idle. I can seriously drive around in 5th at 25mph, about 1000 rpm, and then get up to 55 just fine without downshifting. Theres gobs of low end torque for low rpm acceleration and cruising, and Im finding that its pointless to row thru all 5 gears when I just end up shifting every 5mph (which is every half a second or so lol). I could probably skip 1st, and just go 2-4-5. I swapped the .8 5th gear thats stock in the capri trans to a .71 from a 626. It runs about 2200-2300 rpm at 55. It could probably cruise 55 at 1500. I think I have the tallest 5th gear that came in any G25MR transmission though. The engine just seems to work so much less in the 1800lb festiva than the 2500lb capri. I only wish I could still run the little 12 inch festiva wheels instead of the heavy 15 inch capri wheels.
Now that I have all 4 cylinders working Ive plugged the o2 sensor back in. Im hoping to maintain 40mpg (If I can keep the right foot relaxed), and I'd be super happy if I can get 45 out of it. I averaged 34.5 in the Capri with a best of 38.5. I averaged 47-48 in the stock festiva with a best of 53. So I think logically this should get somewhere between that. I'll keep y'all posted on it.
SRT-4 Intercooler
1/4 mile ET - 12.99
Best MPG - 36.8
capri, festiva, ford, swap, turbo
To Ecomod, or not to ecomod...that is the question. Bart_75_Midget DIY / How-to 3 04-26-2009 01:22 PM
EcoMod Lurker needing help with wrecked Civic HX HDCaptain Introductions 7 12-08-2008 07:55 AM
Why I ecomod. (warning - deep stuff) bennelson EcoModding Central 7 07-25-2008 12:48 PM
electric engine<<what kind do i use>> Begr3en Fossil Fuel Free 6 06-14-2008 02:38 PM
What kind of EV would it take? SVOboy Fossil Fuel Free 40 01-22-2008 07:02 PM
