Old 10-06-2009, 03:09 AM   #11 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
also perhaps this shape is not very favorable when the airflow is off center.
no road is perfectly straight and cars manouvre all the time, so a great portion of your driving the airflow will be comming at the vehicle from a slight angle
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 11-30-2009, 12:19 AM   #12 (permalink)
air doesn't like "wedges"
I'm planning on a 35" raidus half sphere instead if the wedge and relocating the radiator in a 2' extention at the rear.
THX 4 the info guys.
GreenTruckingConcepts.com
Old 11-30-2009, 12:23 AM   #13 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Sorry I didn't spell it out earlier: The more front overhang sticking out there, and the lower it is, the way more likely it is to get scraped off in the real world of driveway approaches, curbs, and whatnot.
Also, there is no aerodynamic need and/or benefit for it to stick out that far anyway so it has more con than pro.
Old 11-30-2009, 12:38 AM   #14 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi Frank,
I'm still having some difficulty with the notion that wedge helped.
I think that the wedge forced the stagnant point as low as possible, which may help keep much of the air out from under the car, and direct as much of it as possibly up and over the car? But, I think it would also do this if it only stuck out 1/2 as far, and then it would not be as likely to scrap the ground.
Old 11-30-2009, 01:16 AM   #15 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
WHAT I'm trying to say is a FLAT one will work, yes, vertical and FLAT if it has decent radii sides and top.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 07:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
