What percentage of atmospheric CO2 is best for plants?
While we have discussed atmospheric CO2 levels in a ridiculously long thread immediately abandoned by its creator, somehow I did not realize that CO2 is measured by parts per million, not percentage.
I read elsewhere that too much carbon dioxide makes water acidic and plants may not create oxygen fast enough for their own needs. I also read that more CO2 will help plants grow, but without increasing other nutrients, they will be deficient. This page states "Ambient levels of CO2 hover around 400-500 ppm. When you increase that level to around 1,000-1,500 ppm, you will see an increase in your yields and your plants will be much healthier." https://www.maximumyield.com/what-ar...ying-it/7/2610 Is this science fair material? |
They to do quite well with double the CO2 we have now.
More plant food, better growth right? You can express atmospheric CO2 as percent, it would just be 0.04%. 400ppm sounds scarier. Doesn't it sound more convincing that we are all going to die if plant food hits 400ppm instead of 0.04%? I work around a dry ice machine where CO2 levels are 1,000 to 2,000ppm and I haven't died. The guy that works in that part of the plant is in it all day he isn't dead either. But I just fix it when he breaks it. |
I haven't studied the subject, but there are universities that experiment with indoor farming, especially in Japan, and they often supplement their crops with additional CO2.
I wonder if merely increasing the air pressure (pressure chamber) would have the effect of promoting growth due to greater concentration of CO2? |
There is supposed to be a cherrie tomato plant in a mall in Japan that is as big as a tree from pressurized co2 to the roots
Also, more is not necessarily better. In addition to CO2 (and O2) from the air, plants generally need, water, sunlight, and soil nitrates, but too much of any of those can kill them. |
I read a comment that 6% CO2 is lethal. Since that would be 60,000 PPM, 133 times current atmospheric levels, hopefully people do not experience that naturally. Quote:
There was a similar link to a document hosted by the University of Washington, but it only talked about filtered light, not increased CO2 levels. |
Our respiration is controlled not by lack of oxygen, but instead concentration of CO2. If the air we breathe in already has a higher concentration of CO2 than what we are designed for, then it slightly alters our respiration impulse. What other things might be affected by a doubling of CO2 concentration? Concerning the study you quoted, the full conclusion is that photosynthesis varies both positively or negatively depending on the pressure the plant is exposed to. Quote:
I don't even worry about CO2 exposure till it hits 3,000ppm.
If CO2 isn't plant food neither is sunlight. Sun light is more harmful to humans than CO2. |
Yeah. Well if it were that simple.
https://www.independent.co.uk/news/s...-a8342521.html Basically there are 2 types of plants: those who move CO₂ actively towards an enzyme (RuBisCO) that absorbs it to prevent it from erroneously taking on oxygen and wasting energy, the so-called C4 plants; and plants that do not (C3 plants). It was thought the C3 plants would benefit from having higher levels of CO₂, but in the long run they don't! Quote:
Food crops will thrive, if carefully fertilized. Natural areas will change. Over time, bacteria may evolve to bind more nitrogen to compensate. But then phosphorus may run out, key minerals, whatever. Life, even wildlife, will be sustainable only if properly monitored and supported. The good news is: we can feed the growing world population; there will be more food available in the future. The bad news: It is going to take a lot of work... |
I have only slept four hours a night for the last few nights. RedDevil, does that say that CO2 benefits plants as long as they have enough other nutrients?
As for the full conclusion that RedPoint shared: High total pressure bad at high humidity. Total pressure up to 0.2 MPa bad with low humidity. Total pressure 0.3 to 0.5 MPa good with low humidity. Increasing total pressure under constant partial pressure of CO2 at 40 Pennsylvania bad. Increasing total pressure and partial pressure of Colorado2 good. So, total pressure 0.3 to 0.5 MPa with low humidity and increasing total pressure and partial pressure of CO2 are good. The other modifications are bad. Is this correct? |
